Home » Eclipse Projects » Plugin Development Environment (PDE) » Headless build not adding jars from binary plug-ins to build path?
Headless build not adding jars from binary plug-ins to build path? [message #57559] Tue, 21 April 2009 21:33 Go to next message
Eric Jain is currently offline Eric JainFriend
I'm trying to set up a headless Ant build for an RCP product, but end up
with the following compilation error:
[javac] Compilation arguments:
[javac] '-noExit'
[javac] '-bootclasspath'
[javac] '...'
[javac] '-classpath'
[javac]
'...;c:\build\plugins\com.springsource.slf4j.api[+org/slf4j/ *;?**/*];'
[javac] 1. ERROR in c:\build\plugins\foo.test\src\test\foo\Bar.java (at
line 6)
[javac] import org.slf4j.Logger;
[javac] ^^^^^^^^^
[javac] The import org.slf4j cannot be resolved
The "missing" class/package is here:
> jar -tf
c:\build\plugins\com.springsource.slf4j.api\com.springsource .slf4j.api-1.5.0.jar
org/slf4j/Logger.class
Also, com.springsource.slf4j.api-1.5.0.jar:META-INF/MANIFEST.MF includes
the following entries:
Bundle-Classpath: com.springsource.slf4j.api-1.5.0.jar
Export-Package: org.slf4j;version="1.5.0";...
Any ideas what's going wrong here? The product builds fine in Eclipse...
Re: Headless build not adding jars from binary plug-ins to build path? [message #57711 is a reply to message #57559] Wed, 22 April 2009 14:33 Go to previous messageGo to next message
Andrew Niefer is currently offline Andrew NieferFriend
> [javac] '-noExit'
> [javac] '...'
> [javac]
It looks like build is considering
"c:\build\plugins\com.springsource.slf4j.api" to be the bundle and not
" c:\build\plugins\com.springsource.slf4j.api\com.springsource .slf4j.api-1.5.0.jar "
What does
c:\build\plugins\com.springsource.slf4j.api/META-INF/MANIFES T.MF say
about Bundle-Classpath?
This looks wrong to me, unless com.springsource.slf4j.api-1.5.0.jar
contains another com.springsource.slf4j.api-1.5.0.jar. This is what the
outer " c:\build\plugins\com.springsource.slf4j.api/META-INF/MANIFES T.MF "
should say. If this inner jar is a bundle in its own right, it should
say "Bundle-Classpath: ." since the classes are in the root of the jar.
Re: Headless build not adding jars from binary plug-ins to build path? [message #57784 is a reply to message #57711] Wed, 22 April 2009 18:01 Go to previous messageGo to next message
> outer " c:buildpluginscom.springsource.slf4j.api/META-INF/MANIFEST.M F "
Sorry: The MANIFEST.MF in com.springsource.slf4j.api-1.5.0:META-INF (not
the one in the jar) contains the two entries I mentioned:
The MANIFEST.MF inside the jar doesn't have a Bundle-Classpath, but it
exports the same package.
If I unpack the jar inside its project, the classes are picked up. So
either headless builds (unlike builds in Eclipse) don't support
Bundle-Classpath, or I'm doing something wrong?
Re: Headless build not adding jars from binary plug-ins to build path? [message #57905 is a reply to message #57784] Thu, 23 April 2009 14:43 Go to previous messageGo to next message
The headless build does support Bundle-Classpath, I don't really have
any idea why it isn't working here. The only case where this doesn't
apply is jars nested in jars because the compiler doesn't support that
kind of classpath entry.
This is the kind of thing I would almost need to run through a debugger
to see what is going wrong. (If you were ambitious, the code is
org.eclipse.pde.build/ClasspathComputer3_0#addPathAndCheck)
-Andrew
>> the outer
>> " c:buildpluginscom.springsource.slf4j.api/META-INF/MANIFEST.M F " should
>> say. If this inner jar is a bundle in its own right, it should say
Re: Headless build not adding jars from binary plug-ins to build path? [message #58152 is a reply to message #57905] Fri, 24 April 2009 04:25 Go to previous messageGo to next message
The javac classpath (as echoed by Ant) contained the following entry;
there is no indication that it is looking at any jar file?
c:\build\plugins\com.springsource.slf4j.api[+org/slf4j/*;?** /*]
In any case I dropped the binary plug-in projects and now deploy the jars
into the target platform; this way the headless build completes without an
error.
Re: Headless build not adding jars from binary plug-ins to build path? [message #512388 is a reply to message #58152] Thu, 04 February 2010 21:33 Go to previous messageGo to next message
Thomas is currently offline ThomasFriend
I just ran into the exact same problem and it seems that by changing "Bundle-Classpath" into "Bundle-ClassPath" (uppercase 'P') in the required plugin manifest (the equivalent for me of the com.springsource.slf4j.api-1.5.0.jar:META-INF/MANIFEST.MF in this example) then it is working.
Does that make sense?
Based on the OSGI R4 spec (r4.core.pdf), it does not seem that the Bundle-Classpath should be with an uppercase 'P'. But when looking through the pde source code, it seems that the org.osgi.framework.Constants.BUNDLE_CLASSPATH is used to get the classpath from the manifest and this constant is using uppercase 'P'......
Re: Headless build not adding jars from binary plug-ins to build path? [message #596110 is a reply to message #57559] Wed, 22 April 2009 14:33 Go to previous messageGo to next message
> [javac] '-noExit'
> [javac] '...'
> [javac]
What does
Re: Headless build not adding jars from binary plug-ins to build path? [message #596146 is a reply to message #57711] Wed, 22 April 2009 18:01 Go to previous messageGo to next message
Re: Headless build not adding jars from binary plug-ins to build path? [message #596209 is a reply to message #57784] Thu, 23 April 2009 14:43 Go to previous messageGo to next message
-Andrew
>> the outer
Re: Headless build not adding jars from binary plug-ins to build path? [message #596318 is a reply to message #57905] Fri, 24 April 2009 04:25 Go to previous messageGo to next message
error.
Re: Headless build not adding jars from binary plug-ins to build path? [message #604515 is a reply to message #58152] Thu, 04 February 2010 21:33 Go to previous message
Previous Topic:updating menu contributions from editor state
Next Topic:PDE Headless Build doesn't work with feature
Current Time: Thu Jun 24 20:05:11 GMT 2021
Powered by FUDForum. Page generated in 0.01723 seconds
