Home » Archived » Eclipse Communications Framework (ECF) » ECF documentation comments
ECF documentation comments [message #570630] |
Tue, 14 December 2004 17:51 |
Li-Te Cheng Messages: 16 Registered: July 2009 |
Congrats on getting accepted as a project! Looking forward to seeing
this happen.
Minor point : on the ECF "dev resources" page,
http://www.eclipse.org/ecf/resources.html , it still says the newsgroup
is eclipse.technology.ecomm ... should be changed to ecf instead.
I was reading through the ECF documentation page at
http://www.eclipse.org/ecf/documentation.html and have a number of
questions/comments. I'm guessing most of this is due to synching up
the docs with recent API changes:
Under "ISharedObject Lifecycle / Initialization"...
"After it has been constructed the container to which it was added will
invoke the ***ISharedObject.init*** ... ISharedObjects created outside
of a container, will have their ***ISharedObjectConfig.init*** method
invoked immediately as part of being added to the container."
Q: Shouldn't the "ISharedObjectConfig.init()" actually be
ISharedObject.init()?
"The ISharedObjectConfig parameter provides the ISharedObject with
access...via a call to ISharedObjectConfig.getContext(). The
ISharedObject is not considered initialized until after the init method
is completed, and therefore the ISharedObjectContext is not available
until after the init method returns."
Q: Should there be a ISharedObject.getConfig() method, so the config and
the context objects can be accessed outside the init() method? This
especially important when sending messages, because ISharedObjectContext
is required, and it's only available from ISharedObjectConfig.
Q: Because there is an implied notion of initialized or not-initialized
states, should there be a ISharedObject.isInitialized() method?
Q: Would it be better to keep things consistent with init() and
isInitialized by having a SharedObjectInitializedEvent (instead of
SharedObjectActivatedEvent)?
Under "Relationship to its container"...
"ISharedObjects can be created outside a ISharedObjectContainer and then
later added to it using the ISharedObjectContainer.addSharedObject()
method"
Q: I see addSharedObject under ISharedObjectManager, not
ISharedObjectContainer - is this a typo?
Under "Sending Messages" and "Receiving Events"
Q: I see "asynchronous" used througout the descriptions, but no mention
of "synchronous". Is "asynchronous" == "non-blocking call" , or
"asynchronous" == "send like email"?
Q: the ISharedObjectContext.sendMessage method would trigger handleEvent
on the receiving ISharedObject. Is it assumed that all messaging events
must subclass the SharedObjectEvent interface? Or should there be a
base SharedObjectMessageEvent interface that messaging events should
subclass, with content corresponding to the parameters in sendMessage(),
i.e.
public interface ISharedObjectMessageEvent extends SharedObjectEvent
public ID getToContainerID();
public Object getData();
If you are concerned about passing data objects around (you might want
to suggest Serializable instead, but that ties down implementations a
lot), then drop the notion of a ISharedObjectMessageEvent, and push
getToContainerID() up to tSharedObjectEvent. It might be useful to have
the "toContainerID" information if the message is being sent to a group
of containers, for example.
Q: Naming issue: should SharedObjectEvent -> ISharedObjectEvent, since
it's an interface, not a class?
Q: When ISharedObject.sendMessage() is called, would it be desirable for
the **sender's** ISharedObject.handleEvent be called as well? This is
particularly useful for UI stuff, e.g. putting "message sent!" or
"message failed - server offline" in a statusbar. Similarly, for the
other "send" methods (e.g. sendDispose)?
Under "Example Creation Code"
Q: "org.eclipse.core.events.SharedObjectActivatedEvent" -->
"org.eclipse.ecf....SharedObjectActivatedEvent"?
Li-Te
Re: ECF documentation comments [message #570818 is a reply to message #570630] |
Wed, 15 December 2004 23:45 |
Scott Lewis Messages: 1038 Registered: July 2009 |
Li-Te wrote:
<stuff deleted>
Yes, this is a typo...I have fixed and checked in fix to
eclipse.org...it (and the other typo you point to below) should be fixed
on the eclipse.org site shortly. Thanks for pointing these out.
method >is completed, and therefore the ISharedObjectContext is not
available >until after the init method returns."
>and the context objects can be accessed outside the init() method?
>This especially important when sending messages, because
>ISharedObjectContext is required, and it's only available from
I think that in classes that implement ISharedObject the answer is
absolutely 'yes'. I would tend to make this a protected (subclasses
only) method...e.g. protected void getConfig().
But I'm not sure it belongs in the ISharedObject interface because the
ISharedObject interface defines an *external* contract that an
ISharedObject has to satisfy (to it's container). And the container is
the source of the ISharedObjectConfig instance, so it doesn't really
need a 'getConfig()' on ISharedObject.
>not-initialized states, should there be a
ISharedObject.isInitialized() >method?
Hmmm. I don't think so...here's my thinking...the ISharedObject
reference is really for the container to use to manage the shared
object. The container controls/manages the initialization, and so
doesn't need to check whether the shared object is initialized. It
could/should probably be in a top-level class that implements
ISharedObject though...certainly for convenience of access internal to
the ISharedObject (and possibly to provide access to other objects).
The intention was to provide an event that notifies the shared object
(and other shared objects that are interested) of the fact that a shared
object has been initialized and now is activated (a state that suggests
not only successful initialization, but also *existence* in the
container relative to other shared objects.
>then later added to it using the
>ISharedObjectContainer.addSharedObject() method"
Yes. I'll fix...thanks. It should/will read:
ISharedObjectContainer.getSharedObjectManager().addSharedObj ect(...)
>mention of "synchronous". Is "asynchronous" == "non-blocking call" ,
>or "asynchronous" == "send like email"?
"send like email". The event is actually sent with a thread separate
from the one that calls init...at least providers have the discretion to
implement it that way.
>handleEvent on the receiving ISharedObject. Is it assumed that all
>messaging events must subclass the SharedObjectEvent interface? Or
>should there be a base SharedObjectMessageEvent interface that
>messaging events should subclass, with content corresponding to the
>parameters in sendMessage(), i.e.
want >to suggest Serializable instead, but that ties down
implementations a >lot), then drop the notion of a
ISharedObjectMessageEvent, and push >getToContainerID() up to
tSharedObjectEvent. It might be useful to >have the "toContainerID"
information if the message is being sent to a >group of containers, for
example.
This seems reasonable. We'll refactor these event class/interface
relationships accordingly.
since it's an interface, not a class?
Yes. Typo...thanks. We'll fix (probably this evening when refactoring
the event interfaces and classes.
>for the **sender's** ISharedObject.handleEvent be called as well?
This >is particularly useful for UI stuff, e.g. putting "message sent!"
or >"message failed - server offline" in a statusbar. Similarly, for
the >other "send" methods (e.g. sendDispose)?
Perhaps...but OTOH, such code might be more appropriately written in the
exception handler for the sendMessage IOException...e.g.
try {
getContext().sendMessage(...);
} catch (IOException e) {
// put "server offline" message to UI here
Yes, this is also a type. It's fixed now...thanks!
Scott
Current Time: Wed Apr 24 15:33:16 GMT 2024
Powered by FUDForum. Page generated in 0.03069 seconds
