Endless rebuilding in IAM Maven Builder [message #569889] |
Thu, 25 June 2009 04:53 |
BenH Messages: 39 Registered: July 2009 |
Member |
In the last few days, our project has been affected by a problem where the
IAM Maven builder continuously rebuilds the project. After each build,
which completes OK without errors, it pauses about 2 secs before the next
one starts. This continues until the IDE crashes with an out of memory
error after 30-45 mins.
Workaround: Disable auto-build. Manually build with Ctl-B as needed.
This behavior seems to be associated with a particular POM, Gmap2 from
Wicketstuff. Its happened on 2 developer machines (Eclipse 3.4.2, IAM 0.9)
and 2 different projects (our own, and gmap2-examples), the common factor
being use of the Gmap2 artefacts.
Here is the details of the open source gmap2-examples project, which shows
this behavior:
<parent>
<groupId>org.wicketstuff</groupId>
<artifactId>gmap2-parent</artifactId>
<version>1.4-SNAPSHOT</version>
</parent>
<artifactId>gmap2-examples</artifactId>
<packaging>war</packaging>
<name>GMap2 - Examples</name>
<description>Examples gmap2 component.</description>
<repositories>
<repository>
<id>org.wicketstuff</id>
<name>Wicket Stuff Repository</name>
<url>http://wicketstuff.org/maven/repository</url>
</repository>
</repositories>
Any help appreciated...
-Ben
FUDForum. Page generated in 0.02501 seconds
