Home » Eclipse Projects » Marketplace Client Project » Cannot find plugin when searching/browsing
Cannot find plugin when searching/browsing [message #569573] Tue, 25 May 2010 11:12 Go to next message
Per Salomonsson is currently offline Per SalomonssonFriend
To be able to use the Marketplace Client from Eclipse i added p2 metadata to the update site and i also logged into http://marketplace.eclipse.org/ and updated the plugin info with feature ID (several days ago).
Then when trying to install the plugin from the Marketplace Client it was listed in the "Recent" tab, but never showed up when searching for it.
I have tried searching for the strings
QuickImage
nu.psnet.quickimage
On http://marketplace.eclipse.org/ i have listed it with the following info:
Solution Name: QuickImage
Update site: http://psnet.nu/eclipse/updates/
Feature id: nu.psnet.quickimage
Any ideas why it doesn't show up?
Re: Cannot find plugin when searching/browsing [message #569608 is a reply to message #569573] Tue, 25 May 2010 19:18 Go to previous messageGo to next message
Ian Skerrett is currently offline Ian SkerrettFriend
This looks like a bug. Can you please open a bugzilla entry.
btw, I noticed you selected 'Other Open Source License'. Please specify this in the bug. What license are you using?
Re: Cannot find plugin when searching/browsing [message #569634 is a reply to message #569573] Wed, 26 May 2010 09:39 Go to previous messageGo to next message
Ok, will open a bugzilla entry.
It's licensed under CPL 1.0.
Re: Cannot find plugin when searching/browsing [message #569654 is a reply to message #569634] Wed, 26 May 2010 12:37 Go to previous messageGo to next message
fyi, not sure if you realize but the OSI has superseded the CPL with the EPL. This means it is no longer an active OSI approved license. You might want to consider updating to use the EPL 1.0.
http://dev.eclipse.org/blogs/mike/2009/04/16/one-small-step- towards-reducing-license-proliferation/
http://opensource.org/licenses/category
Re: Cannot find plugin when searching/browsing [message #569673 is a reply to message #569573] Wed, 26 May 2010 14:09 Go to previous messageGo to next message
I changed the license to EPL, seems to make most sence.
I also filed a bug report https://bugs.eclipse.org/bugs/show_bug.cgi?id=314462
Re: Cannot find plugin when searching/browsing [message #569715 is a reply to message #569573] Thu, 27 May 2010 08:11 Go to previous message
Now it is possible to search for the plugin. Don't know if something changed or i just had to wait a week?
Although, it is not possible to browse to find it. On the marketplace web page it is tagged with the categories "Graphics", "Editor", "Web". But when using the Eclipse Marketplace client it does not show up when selecting All Markets -> Graphics -> [Go].
How do I make the plugin show up under Graphics?
Previous Topic:Marketplace availability in all EPP kits
Next Topic:Cannot find plugin when searching/browsing
Current Time: Mon May 23 10:32:44 GMT 2022
Powered by FUDForum. Page generated in 0.02155 seconds
