Home » Language IDEs » Objectteams » runtime workbench problem
runtime workbench problem [message #569293] Sat, 27 February 2010 02:52 Go to next message
No real name is currently offline No real nameFriend
I try to follow an instruction to create and run a plugin. I cant see runtime workbench under Run As. Can you please help me.
http://onjava.com/pub/a/onjava/2005/02/09/eclipse.html?page= 2
Re: runtime workbench problem [message #569323 is a reply to message #569293] Sat, 27 February 2010 13:55 Go to previous message
Stephan Herrmann is currently offline Stephan HerrmannFriend
It seems this question would better fit into the forum of
the Plugin Development Environment (PDE), but perhaps
the following may already help you:
Instead of "Run As" select "Run Configurations ...".
In that dialog choose "Eclipse Application" and click on
the toolbar buttons with tooltip "New launch configuration".
After you made your choices in the dialog hit "Run".
HTH
Stephan
Previous Topic:runtime workbench problem
Next Topic:Multiple inheritance in OT/J
Current Time: Fri Aug 14 07:03:01 GMT 2020
Powered by FUDForum. Page generated in 0.02544 seconds
