Remote builds after sync [message #566202] |
Tue, 13 February 2007 07:20 |
Jonas Jonsson Messages: 2 Registered: July 2009 |
We're developing an application that should run on multiple platforms, but
most of us are sitting on M$ clients when editing. Some people use Solaris
(Sparc) and some use Linux. The target platforms are Linux and Tru64 on
different hw platforms.
Currently we're transferring the source-code from the repository/view to a
build-server each time we build. We're using rSync for this, and it takes
quite a lot of time since it has to scan the whole source-tree (in a
ClearCase view, slooow) each time before a build.
The build-root on the remote machine is NOT mounted on to the M$ machines,
but access is possible via ssh without passwords.
Is there any way to automate the mirroring of the code, so that once all
the code is transferred at startup, only the updated files (on the client)
gets updated on the build-server?
If not, can someone suggest a good starting-point for creating a plugin
capable of doing this?
Jonas Jonsson
FUDForum. Page generated in 0.02598 seconds
