Home » Eclipse Projects » Webtools incubator » Error creating a java web service
Error creating a java web service [message #562792] Fri, 04 July 2008 09:21
Originally posted by: adrianaverdejo.gmail.com
Hi, I am using the web service wizard to create a java web
service but encountered the following error when the wizard tries to
parse the wsdl:
IWAB0399E Error in generating Java from WSDL java.io.IOException: Type
{http://www.w3.org/2001/XMLSchema}null is referenced but not defined.
IWAB0399E Error in generating Java from WSDL: java.io.IOException: Type
{http://manager.information.myproject.com}Catalogue is referenced but not
defined.
Why is it saying that null is referenced but not defined? Just in
case, below is a snippet of the wsdl generated:
<wsdl:definitions
targetNamespace="http://impl.is.information.myproject.com"
xmlns:apachesoap="http://xml.apache.org/xml-soap"
xmlns:impl="http://impl.is.information.myproject.com"
xmlns:intf="http://impl.is.information.myproject.com"
xmlns:tns1="http://handler.information.myproject.com"
xmlns:tns2="http://exceptions.information.myproject.com"
xmlns:tns3="http://manager.information.myproject.com"
xmlns:wsdl="http://schemas.xmlsoap.org/wsdl/"
xmlns:wsdlsoap="http://schemas.xmlsoap.org/wsdl/soap/"
xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<!--WSDL created by Apache Axis version: 1.4
Built on Apr 22, 2006 (06:55:48 PDT)-->
<wsdl:types>
<schema elementFormDefault="qualified"
xmlns="http://www.w3.org/2001/XMLSchema">
<import namespace="http://handler.information.myproject.com"/>
<import namespace="http://exceptions.information.myproject.com"/>
<import namespace="http://xml.apache.org/xml-soap"/>
<import namespace="http://manager.information.myproject.com"/>
<element name="getGroundingService">
<complexType>
On testing the with web service explorer, I get:
IWAB0380E Errors were encountered while validating XML schemas.
XSD: The location '' has not been resolved because the import is unused
XSD: Type reference 'http://manager.information.myproject.com#Manager' is
unresolved
Is it because the Manager.java cannot be found? In the
reference path, I have checked that the Manager.java is in
there.
How can I solve this?
Thanks for helping.
Adriana
Previous Topic:Error creating a java web service
Next Topic:incubator 1.0M2 (and M1) build?
Current Time: Wed Aug 12 04:33:52 GMT 2020
Powered by FUDForum. Page generated in 0.02423 seconds
