Home » Eclipse Projects » Plugin Development Environment (PDE) » Executing External tool (.exe,.bat etc) from the plugin
Executing External tool (.exe,.bat etc) from the plugin [message #56581] Fri, 17 April 2009 09:57 Go to next message
Shrijeet is currently offline ShrijeetFriend
Hi ,
I am new to plugin development. I was able to successfully write some view
and few other plugins. However my requirement is that I should be able to
execute the external tools through my plugin script.
I was able to execute my executable by makind a new external tool
configuration however I dont know how I can do it from inside my plugin
and not the extenal tool configuration wizard?
Thanks in advance.
~Shri
Re: Executing External tool (.exe,.bat etc) from the plugin [message #56692 is a reply to message #56581] Fri, 17 April 2009 14:13 Go to previous messageGo to next message
Ankur Sharma is currently offline Ankur SharmaFriend
Member
Shrijeet wrote:
> Hi ,
> view and few other plugins. However my requirement is that I should be
> able to execute the external tools through my plugin script.
> Thanks in advance.
> ~Shri
You do it in plugin the same way u wud do it in java. Use Runtime.exec()
hth,
Ankur..
Re: Executing External tool (.exe,.bat etc) from the plugin [message #57039 is a reply to message #56692] Mon, 20 April 2009 06:09 Go to previous message
Thanks... Worked for me!!
Re: Executing External tool (.exe,.bat etc) from the plugin [message #595729 is a reply to message #56581] Fri, 17 April 2009 14:13 Go to previous message
Member
Shrijeet wrote:
> Hi ,
> Thanks in advance.
> ~Shri
hth,
Ankur..
Re: Executing External tool (.exe,.bat etc) from the plugin [message #595876 is a reply to message #56692] Mon, 20 April 2009 06:09 Go to previous message
Previous Topic:Problem with headless build on Eclipse 3.4.2
Next Topic:Enabling update sites when doing a headless build
Current Time: Fri Jul 30 13:40:07 GMT 2021
Powered by FUDForum. Page generated in 0.01538 seconds
