Home » Eclipse Projects » Java Workflow Tooling » Can't install JWT on a fresh version of eclipse
Can't install JWT on a fresh version of eclipse [message #560819] Thu, 12 August 2010 16:57 Go to next message
Darwin is currently offline DarwinFriend
I'm trying to install JWT with the eclipse updater from the p2 servers. Since I was having trouble, I decided to do it on a fresh install of eclipse.
I resolved the dependencies by adding the ATL and GEF sites and it looked like all the dependencies were resolved, but when it was mostly done with installation, it gave me this the following error:
> OK
> Cannot complete the install because one or more required items could not be found.
> Software currently installed: Java Workflow Tooling 1.0.0.v20100719-0900-7N--FJdMh0gj33jLjjgg (org.eclipse.jwt.feature.feature.group 1.0.0.v20100719-0900-7N--FJdMh0gj33jLjjgg)
> Missing requirement: ATL Parser and Compiler 3.1.0.v201006150240 (org.eclipse.m2m.atl.engine 3.1.0.v201006150240) requires 'bundle org.eclipse.m2m.atl.common 0.0.0' but it could not be found
> Cannot satisfy dependency:
> From: Java Workflow Tooling 1.0.0.v20100719-0900-7N--FJdMh0gj33jLjjgg (org.eclipse.jwt.feature.feature.group 1.0.0.v20100719-0900-7N--FJdMh0gj33jLjjgg)
> To: org.eclipse.m2m.atl.engine 3.0.0
I am running Windows 7 32 bit with the Java EE IDE Helios version of eclipse.
Most of the installation guides are out of date. So I was going blind.
I tried to install it by adding the following sites:
http://download.eclipse.org/tools/gef/updates/releases/
http://download.eclipse.org/modeling/m2m/updates/site.xml
http://download.eclipse.org/jwt/update-site/
And then selecting "JWT 1.0.0 R20100719-0900" to install.
Any help is appreciated.
Re: Can't install JWT on a fresh version of eclipse [message #560836 is a reply to message #560819] Mon, 16 August 2010 12:16 Go to previous messageGo to next message
Marc Dutoo is currently offline Marc DutooFriend
Member
Hi Darwin
That's strange, I'll have a look at it.
Did you already read http://wiki.eclipse.org/JWT_SVN , which documents
dependencies ?
Marc
> eclipse.
> Quote:
>> OK
>> not be found.
> eclipse.
Re: Can't install JWT on a fresh version of eclipse [message #560849 is a reply to message #560819] Mon, 16 August 2010 13:40 Go to previous message
Thanks for the link.
I was able to get it to install without errors eventually without the above dependency link.I believe what made the difference was manually installing the m2m package first.
So there does seem to be some dependency issues that don't get identified before installation.
Previous Topic:Can't install JWT on a fresh version of eclipse
Next Topic:Compile Workflow to customized script
Current Time: Sat Nov 17 06:47:02 GMT 2018
Powered by FUDForum. Page generated in 0.02045 seconds
