Re: Trying latest MPC? [message #560298 is a reply to message #560295] |
Mon, 26 April 2010 15:55  |
David Green Messages: 96 Registered: July 2009 |
Member |
Stephan,
Please find answers below:
On 10-04-26 7:45 AM, Stephan Herrmann wrote:
> I was going to give the latest version of the MPC a try,
> yet I failed:
> Installed from http://download.eclipse.org/mpc/repo
> (as announced on the project summary page) yields:
> Discovery completed without finding any extensions.
> Please check your network connection and try again
This is a known problem with initial display of the wizard:
bug 309547: featured/popular URL returns 0 solutions
https://bugs.eclipse.org/bugs/show_bug.cgi?id=309547
If you click on a different tab or do a search, the problem should go away.
> The network connection is OK and there's nothing
> in the logs.
> Trying to install latest from hudson: downloading
> https://build.eclipse.org/hudson/job/epp-mpc-nightly/lastSta bleBuild/artifact/
> unzip and try to install yields
> Location must be absolute: %25update.label
> java.lang.IllegalArgumentException
I'm not sure why you're seeing this problem, I'll look into it. I've created a bug to track this problem. You may want
to CC yourself on the bug:
bug 310480: Installation of the latest build into I20100423-0906 fails with exception
https://bugs.eclipse.org/bugs/show_bug.cgi?id=310480
Installing from a build off of the build server may not always work: these builds often rely on the latest p2 changes
and may also include untested code. If you want to get the latest and greatest, you can try self-hosting with p2
projects in your workspace, or wait until the next milestone build.
David
> FWIW I'm currently on Eclipse I20100423-0906.
> What's the recommended way of trying the latest MPC?
> thanks,
> Stephan
FUDForum. Page generated in 0.01331 seconds
