Home » Archived » DSDP - Real-Time Software Components (RTSC) » DSP Server Wizard(Error: No more handles...)
DSP Server Wizard [message #560194] Tue, 21 September 2010 13:59 Go to next message
Dark Hollow is currently offline Dark HollowFriend
I am trying to bring my company's DSP application into the 21st century. I recently attended a TI workshop (Linux, etc for OMAP and DaVinci) and am now trying to implement the software architecture with full TI tool set support. Initially, just to run a "hello world." Eventually, to integrate our existing stream of consciousness code base.
I am running on a Linux Server (no VMware, etc). I was able to get Lab 5 to run, so I know all my paths should be set correctly for my system.
I then cut to the chase... Lab 12a, which has tool set full integration. I am working with the TI solutions, so cockpit error is unlikely.
When I invoke the DSP Server Wizard, I get a warning message and an error. The warning reminds me to set some environment variables: MOZILLA_FIVE_HOME and LD_LIBRARY_PATH. I did this. But the warning message and the error remain. Here is the error:
Exception in thread "main" org.eclipse.swt.SWTError: No more handles [gtk_init_check() failed]
I am going to check some other path settings, but if this rings any bells for anyone, please enlighten me.
Re: DSP Server Wizard [message #615745 is a reply to message #560194] Tue, 21 September 2010 22:19 Go to previous messageGo to next message
Amit Mookerjee is currently offline Amit MookerjeeFriend
Member
What Linux distribution - Ubuntu -10.04, fedora 13 etc..- are you using. SG applications depend on the browser widget shipped with Mozilla and the warning messages on the console are seen because the mozilla libraries are not detected .
XDCtools supports a really old linux distrbution - enterprise redhat 3.0 - which obviously needs to be upgraded. There is an open bug against XDCtools to support newer linux distributions.
Is the server wizard totally unusable?
Amit
Re: DSP Server Wizard [message #626369 is a reply to message #615745] Wed, 22 September 2010 14:33 Go to previous message
I'm using the MonteVista distribution that came with an eval kit. But I build on a Linux server:
$ cat /proc/version
Linux version 2.6.18-1.2798.fc6 (brewbuilder@hs20-bc2-4.build.redhat.com) (gcc version 4.1.1 20061011 (Red Hat 4.1.1-30)) #1 SMP Mon Oct 16 14:37:32 EDT 2006
Unfortunately, the Server Wizard is totally unusable. And I was counting on the TI Toolsets to work fairly seamlessly when I wrote my schedule. Silly me.
Here is my linux server information:
[Updated on: Wed, 22 September 2010 15:00]
Report message to a moderator
Previous Topic:Increasing Java maxHeapSize programatically in a xs script
Next Topic:error when moving from xdc 3.16.x to 3.20.x
Current Time: Thu Dec 07 05:13:05 GMT 2023
Powered by FUDForum. Page generated in 0.01777 seconds
