Home » Eclipse Projects » Rich Client Platform (RCP) » eclipse plugin / RCP development: migration error from eclipse 3.2 to 3.6
Re: eclipse plugin / RCP development: migration error from eclipse 3.2 to 3.6 [message #628018 is a reply to message #560124] |
Thu, 23 September 2010 08:45 |
Franz Messages: 4 Registered: September 2010 |
I copied and adjusted a MANIFEST.MF under META-INF, as it is in an other RCP-project which this is based on (as far as I understand it).
MANIFEST.MF:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: WAC-RCP
Bundle-SymbolicName: de.gefasoft.webappcfg.rcp;singleton:=true
Bundle-Version: 1.0.0
Bundle-Activator: de.gefasoft.webappcfg.rcp.Activator
Require-Bundle: org.eclipse.ui,
org.eclipse.core.runtime,
org.eclipse.jface.text,
org.eclipse.core.resources,
org.eclipse.ui.editors,
org.eclipse.ui.ide,
org.eclipse.ui.workbench.texteditor,
org.apache.ant,
org.eclipse.debug.core
Eclipse-AutoStart: false
The error changed a bit, but it is still the same behavior: when starting "Launch an Eclipse application" it displays splash.bmp defined in build.properties and exits with "The application could not start. Would you like to view the log?"
The error in the editor is as follows:
org.osgi.framework.BundleException: The bundle "org.eclipse.core.runtime_3.6.0.v20100505 [286]" could not be resolved. Reason: Missing Constraint: Require-Bundle: org.eclipse.equinox.app; bundle-version="[1.0.0,2.0.0)"
The error is slightly different:
- after bundle it is [286] instead of [3] (whatever this means)
- Require-Bundle: org.eclipse.equinox.app (instead of org.eclipse.equinox.common)
- bundle-version="[1.0.0,2.0.0)" instead of "[3.5.0,4.0.0)"
The error !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.core.runtime_3.6.0.v20100505.jar/ was not resolved. is probably still similar as before. "org.eclipse.core.runtime_3.6.0.v20100505.jar" is listed in package explorer.
What does the errors and the error changes mean? How can I locate the error more specifically to fetch the bug?
Re: eclipse plugin / RCP development: migration error from eclipse 3.2 to 3.6 [message #628065 is a reply to message #628018] |
Thu, 23 September 2010 08:52 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
Did you tried hitting "Validate Plug-ins" in your Launch Dialog - it
looks like your launch config is from 3.2 and hence when running it
can't find the new bundles (they have different versions and dependencies)?
Tom
Am 23.09.10 10:45, schrieb Franz:
> MANIFEST.MF:
> org.eclipse.ui.ide,
> org.apache.ant,
> "org.eclipse.core.runtime_3.6.0.v20100505 " could not be resolved.
> - after bundle it is instead of [3] (whatever this means)
> explorer.
Re: eclipse plugin / RCP development: migration error from eclipse 3.2 to 3.6 [message #628271 is a reply to message #628065] |
Thu, 23 September 2010 11:12 |
Hi Tom,
thanks for your answer. I hit "Validation" and the result is shown in this screenshot under picasa (since I cannot upload any images here): http:// picasaweb.google.com/fraensn/Screenshots#5520063394463501714
But I don't know, how I can resolve these "missing constraints"?!
Another thing: I found a warning in "build.properties":
The plug-in's classpath library '.' does not have a corresponding source build entry
What does this mean? Has it any effect - maybe it doesn't find the plugin's then?!
Here's the "build.properties":
bin.includes = plugin.xml,\
plugin.properties,\
icons/,\
about.html,\
config.ini,\
splash.bmp,\
lib/,\
templates/,\
bin/de/,\
bin/,\
META-INF/
src.includes = doc-html/,\
RCP WAC Editor.launch
Tom Schindl wrote on Thu, 23 September 2010 04:52 | Did you tried hitting "Validate Plug-ins" in your Launch Dialog - it
Re: eclipse plugin / RCP development: migration error from eclipse 3.2 to 3.6 [message #628424 is a reply to message #628271] |
Thu, 23 September 2010 12:20 |
What about simply hitting "Add Required Plug-ins"?
Tom
Am 23.09.10 13:12, schrieb Franz:
> Hi Tom,
> http://picasaweb.google.com/fraensn/Screenshots#552006339446 3501714
> build entry
> plugin's then?!
> plugin.properties,\
> icons/,\
> about.html,\
> config.ini,\
> splash.bmp,\
> lib/,\
> templates/,\
> bin/de/,\
> bin/,\
> META-INF/
>> dependencies)?
Current Time: Thu Apr 25 06:07:46 GMT 2024
Powered by FUDForum. Page generated in 0.03736 seconds
