Re: LDAP? [message #56399 is a reply to message #56264] |
Fri, 15 May 2009 18:53 |
No real name Messages: 121 Registered: July 2009 |
Hi Linda,
No, I really meant LDAP. The ODA documentation, if I recall correctly,
states the framework aims to support a broad variety of data sources,
including hierarchical data (eg, XML). Thus I wondered if anyone had
ever tried a LDAP data source.
Thanks, chris
Linda Chan wrote:
> Chris,
> I presume you meant OLAP?
> The ODA framework supports tabular result sets only at this point. There is
> a yet to be scheduled enhancement to support multi-dimensional result sets
> as well (Bugzilla 204345), but it is not going to be in the Galileo release.
> Linda
Re: LDAP? [message #56423 is a reply to message #56399] |
Fri, 15 May 2009 21:15 |
Linda Chan Messages: 845 Registered: July 2009 |
Chris,
I see. A data source's data may be hierarchical, and an ODA driver such as
the DTP enablement.oda.xml driver, flattens its hierarchical data into a
tabular ODA result set. So it is indeed feasible for an LDAP oda driver to
do similar.
Hope others in the community can respond if someone has implemented one for
LDAP.
Linda
Re: LDAP? [message #595735 is a reply to message #56249] |
Thu, 14 May 2009 23:56 |
Chris,
Linda
Re: LDAP? [message #595744 is a reply to message #56264] |
Hi Linda,
Thanks, chris
Linda Chan wrote:
> Chris,
> Linda
Re: LDAP? [message #595749 is a reply to message #56399] |
Chris,
do similar.
LDAP.
Linda
FUDForum. Page generated in 0.03807 seconds
