Home » Eclipse Projects » DTP » LDAP?
LDAP? [message #56249] Thu, 14 May 2009 13:54 Go to next message
No real name is currently offline No real nameFriend
I am a newbie to DTP.
Is it conceivable - or has it already been done - that a ODA data source
is not a tabular (eg, db, csv) but rather a hierarchical information
model (ie, LDAP) ? Or does my question make no sense ?
Thanks, chris
Re: LDAP? [message #56264 is a reply to message #56249] Thu, 14 May 2009 23:56 Go to previous messageGo to next message
Linda ChanFriend
Chris,
I presume you meant OLAP?
The ODA framework supports tabular result sets only at this point. There is
a yet to be scheduled enhancement to support multi-dimensional result sets
as well (Bugzilla 204345), but it is not going to be in the Galileo release.
Linda
Re: LDAP? [message #56399 is a reply to message #56264] Fri, 15 May 2009 18:53 Go to previous messageGo to next message
Hi Linda,
No, I really meant LDAP. The ODA documentation, if I recall correctly,
states the framework aims to support a broad variety of data sources,
including hierarchical data (eg, XML). Thus I wondered if anyone had
ever tried a LDAP data source.
Thanks, chris
Linda Chan wrote:
> Chris,
> Linda
Re: LDAP? [message #56423 is a reply to message #56399] Fri, 15 May 2009 21:15 Go to previous message
Linda ChanFriend
Chris,
I see. A data source's data may be hierarchical, and an ODA driver such as
the DTP enablement.oda.xml driver, flattens its hierarchical data into a
tabular ODA result set. So it is indeed feasible for an LDAP oda driver to
do similar.
Hope others in the community can respond if someone has implemented one for
LDAP.
Linda
Re: LDAP? [message #595735 is a reply to message #56249] Thu, 14 May 2009 23:56 Go to previous message
Linda ChanFriend
Chris,
Linda
Re: LDAP? [message #595744 is a reply to message #56264] Fri, 15 May 2009 18:53 Go to previous message
Hi Linda,
Thanks, chris
Linda Chan wrote:
> Chris,
> Linda
Re: LDAP? [message #595749 is a reply to message #56399] Fri, 15 May 2009 21:15 Go to previous message
Linda ChanFriend
Chris,
do similar.
LDAP.
Linda
Previous Topic:LDAP?
Next Topic:Simple example of ODA Consumer?
Current Time: Thu Apr 25 11:04:25 GMT 2024
Powered by FUDForum. Page generated in 0.03676 seconds
