[Acceleo] Problem execution operation defined in meta model [message #559016] |
Wed, 15 September 2010 06:36  |
I have a method defined in my meta model using OCL. This method is invoked in an MTL file and always produces an error evaluating to an dynamic object reference in the text output.
How is the model to generate to enable the execution of operations defined in OCL in Acceleo?
Simon
Re: [Acceleo] Problem execution operation defined in meta model [message #559038 is a reply to message #559034] |
Wed, 15 September 2010 07:56   |
--------------020105080708090503020200
Simon,
Acceleo Plugin applications mean "in Eclipse" while "Java Application"
mean "standalone". When running standalone applications, you have some
more things to setup (the things Eclipse does for you otherwise).
If I am not mistaken, you should have one (or more) report in your error
log (in Eclipse : Windows => show view => Error Log) saying that one (or
more) package(s) couldn't be found. You'll have to register those
packages as explained on
http://wiki.eclipse.org/MDT/UML2/FAQ#What.27s_required_to_lo ad_a_UML_.28.uml.29_resource_from_a_standalone_application.3 F
or
http://eclipsemde.blogspot.com/2010/06/package-with-uri-not- found.html
(these both use UML as an example).
There might also be some more things to setup from an OCL point of view,
but I don't think so.
Laurent Goubet
Obeo
Simon harrer wrote:
> ok, I will explain in some detail now:
> my metamodel:
> <ecore:EPackage xmi:version="2.0"
> xmlns:xmi="http://www.omg.org/XMI"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="my"
> nsURI="http://my" nsPrefix="my">
> <eAnnotations source="http://www.eclipse.org/emf/2002/Ecore">
> <details key="invocationDelegates"
> value="http://www.eclipse.org/emf/2002/Ecore/OCL"/>
> <details key="settingDelegates"
> <details key="validationDelegates"
> </eAnnotations>
> <eClassifiers xsi:type="ecore:EClass" name="MyTest">
> <eOperations name="testOperation" eType="ecore:EDataType
> http://www.eclipse.org/emf/2002/Ecore#//EString">
> <eAnnotations source="http://www.eclipse.org/emf/2002/Ecore/OCL">
> <details key="body" value="name.concat('asdf')"/>
> </eAnnotations>
> </eOperations>
> <eStructuralFeatures xsi:type="ecore:EAttribute" name="name"
> eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
> </eClassifiers>
> </ecore:EPackage>
> I want to use the operation testOperation() inside my template which is
> shown here:
> [template public generate(m : MyTest)]
> [comment @main /]
> [file (m.name, false, 'UTF-8')]
> [m.testOperation()/]
> [/file]
> [/template]
> If I use this as an AcceleoPluginApplication, everything works. If I run
> this as a JavaApplication, the method could not be instantiated. The
> output then looks the following:
> org.eclipse.emf.ecore.impl.DynamicEObjectImpl@1fc8efd1 (eClass:
> org.eclipse.emf.ecore.impl.EClassImpl@40f892a4 (name: OclInvalid_Class)
> (instanceClassName: null) (abstract: false, interface: false))
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------020105080708090503020200--
FUDForum. Page generated in 0.29423 seconds
