Home » Eclipse Projects » Eclipse 4 » Consistent duplication of custom xwt UI
Consistent duplication of custom xwt UI [message #558887] Tue, 14 September 2010 18:32 Go to next message
St Clair Clarke is currently offline St Clair ClarkeFriend
I have a peculiar problem.
Whenever I create a UI with XWT and embed it in another UI, the embedded UI is duplicated in the application.
For example, I have a xwt UI call CashForm ( I am using Instantiation's/Google Designer to create the UI). I now create a xwt Forms application and embed the NameForm it. Runing the application displays two NameForms UI! Embarrassed
This consistently occurs whenever the process is repeated with different UI forms.
I contacted support at Google and the following is there response
"It seems that XWT first creates the CashForm Composite and then renders its XWT file one more time. You should contact the XWT authors and suggest that they should not do this. I don't see any problem when I drop a CashForm Composite on a normal Java SWT application, so this appears to be an XWT rendering bug."
Hence now I am contacting you.
I cannot attach the files. Some instruction for this please.
I posted Bug 325298 on Bugzilla.
[Updated on: Thu, 16 September 2010 17:15]
Report message to a moderator
Re: Consistent duplication of custom xwt UI [message #559460 is a reply to message #558887] Thu, 16 September 2010 17:16 Go to previous message
Just touching base to see if Bug 325298 was confirmed and
any idea when it will be resolved as I cannot do anything serious
with Forms with this problem.
Thanks.
Previous Topic:Swiching perspectives
Next Topic:Popup Menu for Parts
Current Time: Wed Jul 28 21:39:09 GMT 2021
Powered by FUDForum. Page generated in 0.02525 seconds
