Home » Modeling » EMF » [EMF QUERY] How to get result objects, which are not from the type of the FROM clause?
[EMF QUERY] How to get result objects, which are not from the type of the FROM clause? [message #558822] Tue, 14 September 2010 13:31
Heiko is currently offline HeikoFriend
Member
I have to model instance, which contains 2 Models.
The frist model has only one class node and builds a tree of nodes.
Also every node references to one object of class A from the second
model and also to some objects of class B and class C of the second model.
To define a query, that return back all objects from type node where the
WHERE clause defines the a value of class C eqauls the wanted, works
very well.
It is possible to get back only the objects from class C or do I need to
post process the results?
Heiko
Previous Topic:Contents not loading when using FlatEObjectImpl
Next Topic:De-serialization of complex two-model instance
Current Time: Tue Jul 14 02:48:50 GMT 2020
Powered by FUDForum. Page generated in 0.01441 seconds
