Home » Modeling » EMF » Using EMF in a standalone application / Birt Project - IncompatibleClassChangeError
Using EMF in a standalone application / Birt Project - IncompatibleClassChangeError [message #558498] Mon, 13 September 2010 09:28 Go to next message
Kris Missing name is currently offline Kris Missing nameFriend
Member
I am trying to use a EMF model in a Birt Project.
According to the EMF book "EMF: Eclipse Modeling Framework, 2nd Edition"
(Chapter 20.2 Stand-Alone Applications), I have added the following
plugins to the path of the birt project as well as to report bug
configuration classpath:
org.eclipse.emf.ecore_2.6.1.v20100907-1721.jar
org.eclipse.emf.common_2.6.0.v20100907-1721.jar
Exactly these plugins are referenced in the modeling project (node
"plugin dependencies")
During report debugging of the java event handler classes that are
hooked in the birt report, I get a
java.lang.IncompatibleClassChangeError: Implementing class.
This error arises in the line where I try to get an instance of a model
class:
MyComp c = MyModelFactory.eINSTANCE.createComponent();
I am clueless how to go ahead - any idea what may cause the
IncompatibleClassChangeError?
Kris
Re: Using EMF in a standalone application / Birt Project - IncompatibleClassChangeError [message #558556 is a reply to message #558498] Mon, 13 September 2010 13:17 Go to previous messageGo to next message
Member
in the meantime I found what is causing this error. Due to a bug (*1) in
Birt I updated birt to 2.6.1 RC1 as mentioned in the bug comments via
http://download.eclipse.org/birt/update-site/2.6-interim/
When I revert this update, the IncompatibleClassChangeError is gone.
However, due to the bug from (*1) I need this version of Birt.
Any idea how to get around this - is the also a interim update site for
emf which may resolve this problem?
Kris
(*1) https://bugs.eclipse.org/bugs/show_bug.cgi?format=multiple&a mp;id=318679
Am 9/13/10 11:28 AM, schrieb KW:
> class:
> Thanks
> Kris
Re: Using EMF in a standalone application / Birt Project - IncompatibleClassChangeError [message #558569 is a reply to message #558556] Mon, 13 September 2010 14:13 Go to previous message
Kris,
I've not seen such an error. Is the classpath used for compilation
verses the one you use to run different? Likely it's better if you
structure your project as a plugin, let the PDE manage the classpath,
and then run your stand alone application from that.
KW wrote:
> in Birt I updated birt to 2.6.1 RC1 as mentioned in the bug comments via
> for emf which may resolve this problem?
> Thanks
> Kris
>> Hi,
>> class:
>> Thanks
>> Kris
Ed Merks
Previous Topic:Constraints through Annotations in Ecore model
Next Topic:Difference betweeen constraints and Invariants
Current Time: Fri Aug 07 21:18:52 GMT 2020
Powered by FUDForum. Page generated in 0.01599 seconds
