| Using the EmfModel class [message #558486] |
Mon, 13 September 2010 04:47  |
I have to following problem:
I created a EmfModel object (org.eclipse.epsilon.emc.emf.EmfModel) and then try to load a model in this object.
Therefore I use the following code:
EglFileGeneratingTemplateFactory factory = new EglFileGeneratingTemplateFactory();
EmfModel emfModel = new EmfModel();
StringProperties properties = new StringProperties();
properties.put(EmfModel.PROPERTY_NAME, name);
properties.put(EmfModel.PROPERTY_METAMODEL_FILE, "file:/" + getFile(metamodel).getAbsolutePath());
properties.put(EmfModel.PROPERTY_MODEL_FILE, "file:/" + getFile(model).getAbsolutePath());
properties.put(EmfModel.PROPERTY_IS_METAMODEL_FILE_BASED, "true");
properties.put(EmfModel.PROPERTY_READONLOAD, "true");
//properties.put(EmfModel.PROPERTY_STOREONDISPOSAL, "false");
emfModel.load(properties, null);
factory.getContext().getModelRepository().addModel(emfModel) ;
I didn't receive an error message when I run my program so I think the loading of my model should work fine.
But my problem is that I'm not able to access any concrete data of the model.
Did I something completely wrong?
If necessary you can see in this thread how the model and the meta model looks like.
http://www.eclipse.org/forums/index.php?t=msg&th=175068& amp;start=0&S=2ba7d260f4a39ac0cb5f2531aa9308d8
Andreas
| Re: Using the EmfModel class [message #558503 is a reply to message #558486] |
Mon, 13 September 2010 05:36   |
Hi Andreas,
At a first glance your code looks fine. Could you please be a bit more
specific on the "I'm not able to access any concrete data" issue? Are
you 1) getting an exception when you try to access data of the model, 2)
getting back nothing at all, or 3) not sure how to access data of the
model at all?
Dimitris
Andreas wrote:
> then try to load a model in this object. Therefore I use the following
> code:
> model.
> looks like.
> Best regards,
> Andreas
FUDForum. Page generated in 0.06771 seconds
