Home » Eclipse Projects » Rich Client Platform (RCP) » How to propagate element changes to WritableList's listener?
How to propagate element changes to WritableList's listener? [message #558320] Sat, 11 September 2010 08:47 Go to next message
Frank is currently offline FrankFriend
I found that the listener of WritableList can only be notified if there is any "add", "remove" or "set" operation occurs on the list.
Sometimes, I want to add observable beans to the WritableList, and I want the listener of this WritableList can be notified if the list's element - observable bean - fired property changed event.
I've noticed that this snippet used a observable Person class, which can emit PropertyChangeEvent to listeners. But I cannot understand how the final listener (the TableViewer intance) is able to perceive that event.
Can any body show me a right way to do this? Thanks.
Re: How to propagate element changes to WritableList's listener? [message #558326 is a reply to message #558320] Sat, 11 September 2010 09:21 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
Then you need to create an ObservableMap from the WritableList.
IObservableList l = new WritableList();
IBeanValueProperty p = BeanProperties.value("myattribute");
IObservableMap map = p.observeDetail(l);
map.addMapChangeListener( new IMapChangeListener() {
public void handleMapChange(MapChangeEvent event) {
Tom
Am 11.09.10 10:47, schrieb Frank:
> http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.e xamples.databinding/src/org/eclipse/jface/examples/databindi ng/snippets/Snippet009TableViewer.java?view=markup
Re: How to propagate element changes to WritableList's listener? [message #558332 is a reply to message #558326] Sat, 11 September 2010 09:56 Go to previous messageGo to next message
Thanks, Tom.
p.observeDetail(I) returns IObservableList, right?why IObservableMap?
Tom Schindl wrote on Sat, 11 September 2010 05:21
Tom
Re: How to propagate element changes to WritableList's listener? [message #558336 is a reply to message #558332] Sat, 11 September 2010 10:18 Go to previous messageGo to next message
Oh sorry.
You need to translate the IObservableList into an IObservableSet in case
of a Viewer you can get the set from
ObservableListContentProvider#getKnownElements().
The IObservableMap is informed when *any* of the lists-elements
myproperty changes. If you are not using an
ObservableListContentProvider you can transform an IObservableList using
ListToSetAdapter and the code below reads:
IObservableMap map = p.observeDetail(new ListToSetAdapter(l));
Tom
Am 11.09.10 11:56, schrieb Frank:
> Thanks, Tom.
>> Tom
Re: How to propagate element changes to WritableList's listener? [message #558340 is a reply to message #558336] Sat, 11 September 2010 11:09 Go to previous messageGo to next message
What if I want the final listener get notified not only on "myproperty" property, but any property of the underlying bean?
Re: How to propagate element changes to WritableList's listener? [message #558346 is a reply to message #558340] Sat, 11 September 2010 11:53 Go to previous messageGo to next message
You need to create an IObservableMap for every attribute.
Tom
Am 11.09.10 13:09, schrieb Frank:
Re: How to propagate element changes to WritableList's listener? [message #558356 is a reply to message #558346] Sat, 11 September 2010 15:23 Go to previous message
Smile
Thank you!
Previous Topic:why ComboViewer starts with blank selection?
Next Topic:Zoom funtion in a RCP View?
Current Time: Fri Dec 13 21:51:51 GMT 2024
Powered by FUDForum. Page generated in 0.04449 seconds
