Home » Eclipse Projects » Rich Client Platform (RCP) » why ComboViewer starts with blank selection?
why ComboViewer starts with blank selection? [message #558054] Fri, 10 September 2010 03:16 Go to next message
Frank is currently offline FrankFriend
I constructed a ComboViewer by giving it both content provider and label provider, it works ok, but it is annoying that the combo viewer always start with a blank selection, even though I declared this:
comboViewer.getCombo().select( 0 );
or this:
comboViewer.setSelection( new StructuredSelection(list[0]) );
How can I avoid that blank selection?
[Updated on: Fri, 10 September 2010 03:18]
Report message to a moderator
Re: why ComboViewer starts with blank selection? [message #558109 is a reply to message #558054] Fri, 10 September 2010 08:09 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
When are you doing this call. It has to be after the setInput() call.
Tom
Am 10.09.10 05:16, schrieb Frank:
> provider, it works ok, but it is annoying that the combo viewer start
> with a blank selectio always, even though I declared this:
> or this:
Re: why ComboViewer starts with blank selection? [message #558123 is a reply to message #558109] Fri, 10 September 2010 09:17 Go to previous messageGo to next message
Here is my code snippet
    comboViewer = new ComboViewer( this, SWT.READ_ONLY );
    comboViewer.getCombo().setLayoutData( gridData1 );
    IStructuredContentProvider contentProvider = ArrayContentProvider.getInstance();
    comboViewer.setContentProvider( contentProvider );
    ILabelProvider labelProvider = new LabelProvider()
        public String getText( Object element )
          MyExtension extension = (MyExtension) element;
          return extension.getDisplayText();
    comboViewer.setLabelProvider( labelProvider );
    MyExtension[] extensions = MyExtensions.getExtensions();
    comboViewer.setInput(extensions);
    // TODO avoid blank selection
Re: why ComboViewer starts with blank selection? [message #558127 is a reply to message #558123] Fri, 10 September 2010 09:32 Go to previous messageGo to next message
I feel that I have found the reason, but I don't know how to resolve it.
All those control settings are contained in a Dialog, the setSelection method doesn't work, of course, before the Dialog opens.
I want the selection be set when the Dialog opens.
Re: why ComboViewer starts with blank selection? [message #558129 is a reply to message #558123] Fri, 10 September 2010 09:20 Go to previous messageGo to next message
What is this - a composite?
Tom
Am 10.09.10 11:17, schrieb Frank:
> @Override
Re: why ComboViewer starts with blank selection? [message #558135 is a reply to message #558127] Fri, 10 September 2010 09:49 Go to previous messageGo to next message
So you are saying that the call has no effect when done before the shell
is shown?
Can you give use more details about your Eclipse version, OS, ... and
some snippet we can run to reproduce the problem?
Tom
Am 10.09.10 11:32, schrieb Frank:
Re: why ComboViewer starts with blank selection? [message #558324 is a reply to message #558135] Sat, 11 September 2010 09:20 Go to previous message
Thank you very much Tom.
I'm sorry that it turns out to be my fault. I introduced a bug to the data-binding part of my code.
Sorry.
Previous Topic:showView fails to show the view from preShutdown()
Next Topic:How to propagate element changes to WritableList's listener?
Current Time: Wed Dec 04 15:49:59 GMT 2024
Powered by FUDForum. Page generated in 0.03591 seconds
