Re: customized report by windows folder files [message #558000 is a reply to message #557899] |
Thu, 09 September 2010 17:36 |
How is the data stored? In a flat file?
Jason
On 9/9/2010 7:32 AM, francesco wrote:
> i have just installed BIRT on my home pc.....
> i'd like to make a customized report using data stored on a folder on my
> own pc folder. i have a windows s.o,
> Is this possible without loading data into a db?
> I know a little of java languages and i can't install a data base on my
> own pc...
> Please someone can help me with this kind of situations?
> Francesco....:d
Re: customized report by windows folder files [message #558242 is a reply to message #558195] |
Fri, 10 September 2010 15:50 |
BIRT does not have to get data from a db. BIRT can read csv, tsv, psv
type files. So if your files are in a delimited format you should be
able to just use the flat file datasource wizard to get your data.
Jason
On 9/10/2010 9:40 AM, francesco wrote:
> Hi Jason,
> thank a lot for your interest about my situation :d
> i have to make e customized report having some file from evt security
> log of my own pc.....
> the problem is that i don't have a db and i can't install one on my home
> pc.
> So i want to use the file exctracetd on a folder cerated on my pc to
> make a data source file in order to BIRT recognize the folder like a
> data base....
> I have read some articles about this trick and i have undestood i have
> to use a java code to do this but i don't know how to make that.
> Can you tell me if this is possible and how to make it?
> Best regards,
> Francesco :D:D:D:D
FUDForum. Page generated in 0.03272 seconds
