Re: Running the EGL example [message #558502 is a reply to message #558392] |
Mon, 13 September 2010 09:31 |
Dimitrios Kolovos Messages: 1776 Registered: July 2009 |
Hi Andreas,
I've received your email but haven't had a chance to look at it yet.
I'll hopefully do so and get back to you later on today.
Dimitris
Andreas wrote:
> Hi Dimitris,
> sure I can provide you some more information.
> I have a trace model (xmi file) with was generated during a model to
> model transformation. Now I want to generate something like a coverage
> report from that trace model. So I want to read the trace model,
> calculate some things and then generate a HTML report from this
> information. But at the moment, I'm not able to access the concrete data
> within the trace model. I only can access the meta model level.
> How the meta model of the trace model looks like, you can see here:
> A small version of a concrete trace model could look like this:
> Till now I haven't found a way to access the attributes like id, name,
> modelID, ...
> I also already sent you my sample project on your GMail account. I hope
> you received it.
> Andreas
Re: Running the EGL example [message #593660 is a reply to message #593634] |
Hi Andreas,
Dimitris
Andreas wrote:
> Hi Dimitris,
> modelID, ...
> you received it.
> Andreas
FUDForum. Page generated in 0.06336 seconds
