Re: [Acceleo 3] Question about debugging templates [message #557659 is a reply to message #557523] |
Wed, 08 September 2010 13:00 |
Hi Tom,
In Acceleo 3.0, we notify the user with marker for any error during the parsing (if you forget to close a block for example). Parsing problems are visible in the editor. We will also have warnings and informations (TODO / FIXME) in Acceleo 3.1 (example). And during the generation, we also notify the user if something goes wrong, this time in the console.
Do you have a specific kind of error that was detected in Acceleo 2, that is not detected in Acceleo 3 ?
Stephane Begaudeau, Obeo
Re: [Acceleo 3] Question about debugging templates [message #557668 is a reply to message #557659] |
Wed, 08 September 2010 13:17 |
--------------040505060702060204090601
Hi Tom,
To complete, we do not intend on reporting "runtime" errors in the
template editor itself for Acceleo 3. The console and error log display
stack traces corresponding to "in which module did the failure happen,
an on which line". We consider these stack trace to be more powerful
than a simple red marker in the editor, as it allows you to trace
exactly from which templates the call leading to a failure came.
Laurent Goubet
Obeo
Stephane Begaudeau wrote:
> Hi Tom,
> ( http://sbegaudeau.tumblr.com/post/961722949/user-interface-i mprovements-in-acceleo-3-1).
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------040505060702060204090601--
FUDForum. Page generated in 0.02672 seconds
