Re: [Acceleo] Problem with String replaceAll [message #557219 is a reply to message #557183] |
Mon, 06 September 2010 07:31 |
--------------080000050504040208080105
Happy to see you fixed it, though your first post does point to an error
we need to fix in the core.
Could you raise a bug about the "replaceAll(..)" operation throwing an
exception when called on an undefined String?
Laurent Goubet
Obeo
galluzzo@gmail.com wrote:
> I figured out that I had the properties set up wrong. All fixed now...
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------080000050504040208080105--
Re: [Acceleo] Problem with String replaceAll [message #557391 is a reply to message #557182] |
Tue, 07 September 2010 09:24 |
Hi Tom,
What version of Acceleo are you using ? 3.0 or 3.1M1 ? You can see it in "Help -> About Eclipse -> Installation Details -> Plugins"
And for your bug, well I think I solved it with another bug few days ago that was similar, because I can't reproduce it in my developement version so the fix should be available in Acceleo 3.1 and Acceleo 3.0 SR1 or SR2.
Stephane Begaudeau, Obeo
FUDForum. Page generated in 0.02617 seconds
