Re: bubble charts [message #557020 is a reply to message #556916] |
Fri, 03 September 2010 16:14 |
I believe the problem is that the size is already used before the
beforeDrawDataPoint event occurs. You may want to log a bug for this.
As a work around change it in a prior script. For example in the
afterComputations like:
function afterComputations( chart, plotComputation )
importPackage(Packages.java.lang);
var xAxis = chart.getAxes().get(0);
var yAxis = xAxis.getAssociatedAxes().get(0);
var xSerieDef = xAxis.getSeriesDefinitions().get(0);
var ySerieDef = yAxis.getSeriesDefinitions().get(0);
var ySerie = ySerieDef.getRunTimeSeries().get(0);
var dpa =
plotComputation.getSeriesRenderingHints(ySerieDef,ySerie).ge tDataPoints();
for( ii =0; ii<dpa.length; ii++ ){
var csize = dpa[ii].getOrthogonalValue().getSize();
dpa[ii].getOrthogonalValue().setSize( Double.parseDouble( csize)*.3);
Jason
On 9/3/2010 3:58 AM, manfred.drescher@finaware.ch wrote:
> The sizes of the bubbles are calculated and set automatically by birt
> In many cases the sizes of all bubbles are too big, i want to have for
> example:
> - a maximum size for all bubbles
> - or multiply all bubble sizes with a factor for example with 0.3
> - any other way that avoids extremely big bubbles overlapping many other
> bubbles.
> I tried this script without success:
> function beforeDrawDataPoint( dph, fill, icsc )
> mybubbleval = dph.getOrthogonalValue(); if(
> mybubbleval.getClass().toString() == "class
> org.eclipse.birt.chart.datafeed.BubbleEntry") {
> mybubbleval.setSize(1);
> Many thank's for helping.
FUDForum. Page generated in 0.02607 seconds
