Home » Eclipse Projects » Plugin Development Environment (PDE) » Using a config.ini in a PDE run configuration
Using a config.ini in a PDE run configuration [message #55934] |
Thu, 16 April 2009 15:42 |
Craig L. Ching Messages: 21 Registered: July 2009 |
I am trying to set up an environment for developing an equinox-based
application. This is a server-based application, not a UI application,
but the tools for the run environment make me think this is the right
place to ask this. So correct me if I'm wrong ;-)
I'm following this tutorial:
http://springosgi.googlepages.com/
And that works great, I can create a target platform to work in no
problem. However, I have a config.ini that I'd like to use to specify
the bundles I want (though this wouldn't be a hard requirement) and to
specify the osgi variable 'org.osgi.framework.system.packages'.
The problem I'm running into is that if I specify a configuration area,
when I run the platform, my config.ini is over-written. I tried
specifying 'org.osgi.framework.system.packages' in the VM arguments, but
packages near the end seem to be ignored (I'm guessing there's a limit
to how big the command line for the VM argument can be).
Is there any way to get the target platform to use my config.ini without
modifying it?
Thanks for any pointers!
Craig
Re: Using a config.ini in a PDE run configuration [message #55971 is a reply to message #55934] |
Thu, 16 April 2009 15:50 |
Chris Aniszczyk Messages: 674 Registered: July 2009 |
Craig L. Ching wrote:
> modifying it?
When you're selfhosting, in Eclipse Application launch configuration,
there should be a "Configuration" tab where you can specify a config.ini
to use. Note that in 3.5, we're working on removing that and just
allowing you to specify a set of properties.
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: Using a config.ini in a PDE run configuration [message #55997 is a reply to message #55971] |
Thu, 16 April 2009 15:58 |
>> Hi,
[snip]
>> without modifying it?
Aha! At first I thought "WTF?!?! I don't recall seeing a
'Configuration' tab!!!" but then I see there is an "Eclipse Application"
(as you suggest) type that has a configuration tab, the "OSGI
Framework" run configuration, which is what I was using, does not.
Thank you so much Chris, I'll have a look at doing an Eclipse
Application run configuration instead!
> Cheers,
Craig
Re: Using a config.ini in a PDE run configuration [message #56103 is a reply to message #56051] |
Thu, 16 April 2009 16:14 |
>> Application" (as you suggest) type that has a configuration tab, the
>> "OSGI Framework" run configuration, which is what I was using, does
>> not. Thank you so much Chris, I'll have a look at doing an Eclipse
> Both of the launch configurations are near identical... especially when
> Eclipse 3.5 comes out.
Cool, I might have to download a snapshot then.
> You should still be able to pass OSGi properties as system properties
> via -Dosgi.property=foo in the OSGi launch configuration.
Yeah, but I have a lot of system packages to make available to the
runtime and I *think* that the length of the command line is limiting me.
BTW, I still seem to have my config.ini overwritten. I'm going to try a
couple more things, but is it expected that the eclipse run config is
going to overwite an existing config.ini if I tell the run config that
the configuration area is in the same directory where my template
config.ini lives? Also, the overwritten config.ini still doesn't have
my system packages variable in it.
> Cheers,
Craig
Re: Using a config.ini in a PDE run configuration [message #595504 is a reply to message #55934] |
> modifying it?
Re: Using a config.ini in a PDE run configuration [message #595517 is a reply to message #55971] |
>> Hi,
[snip]
> Cheers,
Craig
Re: Using a config.ini in a PDE run configuration [message #595546 is a reply to message #56051] |
> Cheers,
Craig
Current Time: Tue Apr 23 08:11:55 GMT 2024
Powered by FUDForum. Page generated in 0.04278 seconds
