Home » Eclipse Projects » Linux Tools Project » using the ChangeLog plugin without CVS
using the ChangeLog plugin without CVS [message #556254] Tue, 31 August 2010 13:35 Go to next message
Lorenzo Bettini is currently offline Lorenzo BettiniFriend
I currently switched many of my programs from CVS to Git I see that the
ChangeLog entry in the edit menu is not available anymore... I'm not
talking about the automatic ChangeLog generation from the CVS repository
(I saw that integration with git is under development), but only the
possibility of creating a ChangeLog entry from the currently edited file
(independently from the repository). Is there a way to achieve this?
thanks in advance
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: using the ChangeLog plugin without CVS [message #556336 is a reply to message #556254] Tue, 31 August 2010 20:53 Go to previous messageGo to next message
Severin Gehwolf is currently offline Severin GehwolfFriend
Member
Hi Lorenzo,
Creating Changelog entries via <CTRL>+<ALT>+C works for me. I'm also seeing the entry in the "Edit" menu. I'm testing this on Eclipse 3.5.2 using an EGit project.
What exactly are you doing? What are the precise steps to reproduce this? What version of Eclipse are you using? How did you install Eclipse + plug-ins?
Severin
Re: using the ChangeLog plugin without CVS [message #557231 is a reply to message #556336] Mon, 06 September 2010 08:15 Go to previous messageGo to next message
On 08/31/2010 10:53 PM, Severin Gehwolf wrote:
> Hi Lorenzo,
> + plug-ins?
> Severin
I'm using eclipse helios and the current version of linux tools...
probably it's a problem with the current version? It used to work with
the Galileo version as far as I remember...
cheers
Lorenzo
Re: using the ChangeLog plugin without CVS [message #558682 is a reply to message #557231] Mon, 13 September 2010 22:50 Go to previous messageGo to next message
Member
Edit => Changelog Entry seems to be functional for me on Helios + Egit. <ctrl>+<alt>+c does not work for me, though. I am suspecting keyboard shortcut conflicts at my end. <ctrl>+<alt>+c is also something EGit uses. Do you have key-binding conflicts showing up in your error log too?
Severin
Re: using the ChangeLog plugin without CVS [message #558988 is a reply to message #558682] Wed, 15 September 2010 09:02 Go to previous messageGo to next message
Apart from keyboard shortcut, what worries me is that "Edit => Changelog
Entry" does not show up...
Re: using the ChangeLog plugin without CVS [message #559254 is a reply to message #558988] Thu, 16 September 2010 07:48 Go to previous messageGo to next message
mh... now I have a doubt... probably something has changed in linuxtool
0.6 and changelog is not part of the update site for linuxtools plugins
anymore?
Indeed, I only see these plugins in my helios installation
../plugins/org.eclipse.linuxtools.cdt.autotools_2.0.0.201006 152250.jar
../plugins/org.eclipse.linuxtools.cdt.autotools_docs_2.0.1.2 01006152250
../plugins/org.eclipse.linuxtools.cdt.autotools.core_1.0.0.2 01006152250.jar
../plugins/org.eclipse.linuxtools.cdt.autotools.ui_1.0.0.201 006152250.jar
../features/org.eclipse.linuxtools.cdt.autotools_2.0.0.20100 6152250
and here http://www.eclipse.org/linuxtools/projectPages/changelog/ I see
"At present we have no update site, but you can check the project
plugins out of SVN directly from eclipse.org at
svn://dev.eclipse.org/svnroot/technology/org.eclipse.linuxto ols"
So now I need to build the changelog plugin myself?
thanks
Lorenzo
Re: using the ChangeLog plugin without CVS [message #559346 is a reply to message #559254] Thu, 16 September 2010 12:55 Go to previous messageGo to next message
Member
Lorenzo Bettini wrote on Thu, 16 September 2010 03:48
anymore?
You should be able to get the changelog plugin from our regular update sites as described here:
http://www.eclipse.org/linuxtools/downloads.php
If you have one of those sites enabled and installation went OK, but changelog does not show up in installation details, could you try to start eclipse from a terminal like so:
$ path/to/eclipse/install/eclipse -debug -consolelog
Do you see something which indicates that the changelog bundle isn't loading properly?
HTH,
Severin
[Updated on: Thu, 16 September 2010 12:55]
Report message to a moderator
Re: using the ChangeLog plugin without CVS [message #570022 is a reply to message #556254] Tue, 31 August 2010 20:53 Go to previous messageGo to next message
Member
Hi Lorenzo,
Severin
Re: using the ChangeLog plugin without CVS [message #570129 is a reply to message #570022] Mon, 06 September 2010 08:15 Go to previous messageGo to next message
> Hi Lorenzo,
> + plug-ins?
> Severin
cheers
Lorenzo
Re: using the ChangeLog plugin without CVS [message #570147 is a reply to message #557231] Mon, 13 September 2010 22:50 Go to previous messageGo to next message
Member
Severin
Re: using the ChangeLog plugin without CVS [message #570171 is a reply to message #570147] Wed, 15 September 2010 09:02 Go to previous messageGo to next message
Re: using the ChangeLog plugin without CVS [message #570185 is a reply to message #558988] Thu, 16 September 2010 07:48 Go to previous messageGo to next message
anymore?
thanks
Lorenzo
Re: using the ChangeLog plugin without CVS [message #570205 is a reply to message #559254] Thu, 16 September 2010 12:55 Go to previous messageGo to next message
Member
> anymore?
If you have those sites enabled and installation went OK, but changelog does not show up in installation details, could you try to start eclipse from a terminal like so:
HTH,
Severin
Re: using the ChangeLog plugin without CVS [message #629125 is a reply to message #570205] Mon, 27 September 2010 09:50 Go to previous messageGo to next message
>> linuxtool 0.6 and changelog is not part of the update site for
>> linuxtools plugins anymore?
>> 01006152250.jar
>> 006152250.jar
> loading properly?
> HTH,
> Severin
Severin
that update site is already part of my eclipse, but no changelog plugin
is available for installation...
moreover, sorry if I insist on this, but it looks like the changelog
plugin is not available at all from an update site, as it is state here:
svn://dev.eclipse.org/svnroot/technology/org.eclipse.linuxto ols You
will need to check out the following from changelog/trunk:
org.eclipse.linuxtools.changelog.core
org.eclipes.linuxtools.changelog-feature
org.eclipse.linuxtools.changelog.cparser
org.eclipse.linuxtools.changelog.doc
org.eclipse.linuxtools.changelog.javaparser
From there, run the plugins as an Eclipse Application.
Re: using the ChangeLog plugin without CVS [message #629253 is a reply to message #629125] Mon, 27 September 2010 15:34 Go to previous messageGo to next message
Member
Lorenzo Bettini wrote on Mon, 27 September 2010 05:50
Are you sure? When I point my Web browser to
http://download.eclipse.org/technology/linuxtools/update I'm seeing:
<feature url="features/org.eclipse.linuxtools.changelog_2.6.7.201008261754.jar" id="org.eclipse.linuxtools.changelog" version="2.6.7.201008261754">
      <category name="Linux Tools"/>
</feature>
In other words, a changelog build from 2010-08-26 is part of this update site. Required plugin jars are there for me too. Similar for updates-nightly. I still think you should be able to get a pre-built version from either of those.
Have you tried updating/reinstalling from your existing update site?
I think this information is outdated. Sorry about that.
Re: using the ChangeLog plugin without CVS [message #634988 is a reply to message #629253] Mon, 25 October 2010 09:56 Go to previous message
>> plugin is available for installation...
> <feature
> url=" features/org.eclipse.linuxtools.changelog_2.6.7.201008261754 .jar "
> </feature>
>> here: http://www.eclipse.org/linuxtools/projectPages/changelog/
I found the plugin! It is in General Tools... I was expecting to find
it in the Linux Tools section...
cheers
Lorenzo
Previous Topic:LTTng and multi-core
Next Topic:Need o profile plug -in for windows
Current Time: Tue May 18 01:12:20 GMT 2021
Powered by FUDForum. Page generated in 0.02118 seconds
