Home » Eclipse Projects » Platform - User Assistance (UA) » Infocenter as Webapp - Problems (Tomcat)(Exception occurs)
Infocenter as Webapp - Problems (Tomcat) [message #556156] Tue, 31 August 2010 07:29 Go to next message
Matthias is currently offline MatthiasFriend
Member
I'm trying to run Infocenter on Tomcat. My Help system works when I start the infocenter over the command line but I want to use tomcat.
I've deployed the infocenter.war which I downloaded from the eclipse homepage. After setting the eclipse_home in web.xml I get the following error:
exception
org.apache.jasper.JasperException: Could not find bootstrap code. Check location of boot plug-in or specify -boot.
	org.apache.jasper.servlet.JspServletWrapper.handleJspException(JspServletWrapper.java:476)
	org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:371)
	org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:315)
	org.apache.jasper.servlet.JspServlet.service(JspServlet.java:265)
	javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
root cause
javax.servlet.ServletException: Could not find bootstrap code. Check location of boot plug-in or specify -boot.
	org.eclipse.help.servlet.InitServlet.init(InitServlet.java:46)
	javax.servlet.GenericServlet.init(GenericServlet.java:212)
	org.apache.jsp.index_jsp._jspService(index_jsp.java:48)
	org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:98)
	org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:328)
root cause
	org.eclipse.help.servlet.Eclipse.init(Eclipse.java:150)
	org.eclipse.help.servlet.Eclipse.<init>(Eclipse.java:33)
	org.eclipse.help.servlet.InitServlet.init(InitServlet.java:38)
root cause
java.lang.RuntimeException: Could not find bootstrap code. Check location of boot plug-in or specify -boot.
	org.eclipse.help.servlet.Eclipse.searchForBoot(Eclipse.java:213)
	org.eclipse.help.servlet.Eclipse.getBootLoader(Eclipse.java:89)
	org.eclipse.help.servlet.Eclipse.init(Eclipse.java:108)
note The full stack trace of the root cause is available in the Apache Tomcat/5.5.23 logs.
I've tried also to create my own webapp with different tutorials but after the last steps I only get this error.
Please give me some hints!
Thanks in advance
[Updated on: Tue, 31 August 2010 08:51]
Report message to a moderator
Re: Infocenter as Webapp - Problems (Tomcat) [message #556252 is a reply to message #556156] Tue, 31 August 2010 13:24 Go to previous messageGo to next message
Chris Austin is currently offline Chris AustinFriend
I would recommend trying to build the war using the help documentation first (for 3.6 it is here):
http://help.eclipse.org/helios/topic/org.eclipse.platform.do c.isv/guide/ua_help_war.htm
Then you can work on customizing it.
Re: Infocenter as Webapp - Problems (Tomcat) [message #556263 is a reply to message #556156] Tue, 31 August 2010 14:26 Go to previous messageGo to next message
Member
I used the help documentation and my errors were the result. I will try it again tomorrow, maybe I skipped something.
I have also tried it with this guide:
http://blog.maxant.co.uk/pebble/2008/06/09/1213043100000.htm l
Same result.
Re: Infocenter as Webapp - Problems (Tomcat) [message #556380 is a reply to message #556156] Wed, 01 September 2010 06:15 Go to previous messageGo to next message
Member
Today I tried another complete version, it gives me another exception but I think I am near to the wished result.
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
javax.servlet.ServletException: Servlet.init() for servlet equinoxbridgeservlet threw exception
	org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
	org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:151)
	org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:870)
	org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:665)
	org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:528)
	org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:81)
	org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:685)
	java.lang.Thread.run(Thread.java:619)
root cause
java.lang.IllegalStateException: instance already set
	org.eclipse.equinox.servletbridge.BridgeServlet.setInstance(BridgeServlet.java:184)
	org.eclipse.equinox.servletbridge.BridgeServlet.init(BridgeServlet.java:44)
Any proposes?
Edit:
Now I tried the manual in eclipse help, again. I got the following error:
message
exception
root cause
[Updated on: Wed, 01 September 2010 07:36]
icon9.gif  Re: Infocenter as Webapp - Problems (Tomcat) [message #556629 is a reply to message #556156] Thu, 02 September 2010 07:23 Go to previous messageGo to next message
Member
Another update:
I've tried a war from https://bugs.eclipse.org/bugs/show_bug.cgi?id=201666. Maybe it's not compatible with my eclipse 3.5.1 and Tomcat 5.5?
In my /WEB-INF/eclipse/plugins directory org.eclipse.core.runtime_3.4.0.v20080512.jar exists...
Here is the complete stackstrace:
02.09.2010 09:14:01 org.apache.catalina.core.ApplicationContext log
SCHWERWIEGEND: Error while starting Framework
java.lang.ClassNotFoundException: org.eclipse.core.runtime.adaptor.EclipseStarter
	at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1359)
	at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1205)
	at org.eclipse.equinox.servletbridge.FrameworkLauncher$ChildFirstURLClassLoader.loadClass(FrameworkLauncher.java:650)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
	at org.eclipse.equinox.servletbridge.FrameworkLauncher.start(FrameworkLauncher.java:209)
	at org.eclipse.equinox.servletbridge.BridgeServlet.init(BridgeServlet.java:63)
	at javax.servlet.GenericServlet.init(GenericServlet.java:212)
	at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1139)
	at org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:966)
	at org.apache.catalina.core.StandardContext.loadOnStartup(StandardContext.java:3956)
	at org.apache.catalina.core.StandardContext.start(StandardContext.java:4230)
	at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:760)
	at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:740)
	at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:544)
	at org.apache.catalina.startup.HostConfig.deployDirectory(HostConfig.java:920)
	at org.apache.catalina.startup.HostConfig.deployDirectories(HostConfig.java:883)
	at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:492)
	at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1138)
	at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:311)
	at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:120)
	at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1022)
	at org.apache.catalina.core.StandardHost.start(StandardHost.java:736)
	at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1014)
	at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:443)
	at org.apache.catalina.core.StandardService.start(StandardService.java:448)
	at org.apache.catalina.core.StandardServer.start(StandardServer.java:700)
	at org.apache.catalina.startup.Catalina.start(Catalina.java:552)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:295)
	at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:433)
SCHWERWIEGEND: StandardWrapper.Throwable
java.lang.RuntimeException: org.eclipse.core.runtime.adaptor.EclipseStarter
	at org.eclipse.equinox.servletbridge.FrameworkLauncher.start(FrameworkLauncher.java:225)
02.09.2010 09:14:01 org.apache.catalina.core.StandardContext loadOnStartup
SCHWERWIEGEND: Servlet /help threw load() exception
02.09.2010 09:14:14 org.apache.catalina.core.ApplicationContext log
	at org.eclipse.equinox.servletbridge.BridgeServlet.setInstance(BridgeServlet.java:184)
	at org.eclipse.equinox.servletbridge.BridgeServlet.init(BridgeServlet.java:44)
	at org.apache.catalina.core.StandardWrapper.allocate(StandardWrapper.java:791)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:127)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:174)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:151)
	at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:870)
	at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:665)
	at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:528)
	at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:81)
	at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:685)
	at java.lang.Thread.run(Thread.java:619)
02.09.2010 09:14:14 org.apache.catalina.core.StandardWrapperValve invoke
SCHWERWIEGEND: Allocate exception for servlet equinoxbridgeservlet
Re: Infocenter as Webapp - Problems (Tomcat) [message #556642 is a reply to message #556156] Thu, 02 September 2010 07:58 Go to previous messageGo to next message
Member
Now I just extracted org.eclipse.osgi_3.4.0.v20080605-1900.jar into /plugins (It was already in the plugin-folder but packaged in the same-named plugin as jar) and the osgi prompt appears.
When I browse to localhost:8080/help a page appears but it doesn't look like infocenter.
The header-frame has the content "Mit dieser XML-Datei sind anscheinend keine Style-Informationen verknüpft. Nachfolgend wird die Baum-Ansicht des Dokuments angezeigt."
The frame at the bottom has only "
<component name="Help System Webapp" version="1.1">
<plugin id="org.eclipse.help.webapp"/>
</component>"
as content.
Maybe is there an error with the permission of the filesystem so that eclipse may not extract the jars to work with them or something like this?
Thanks in advance
Re: Infocenter as Webapp - Problems (Tomcat) [message #556926 is a reply to message #556156] Fri, 03 September 2010 08:22 Go to previous message
Member
My last post is the solution to my problem. I only had to brrowse directly to index.jsp and my help shows up!
Previous Topic:Infocenter Mapping
Next Topic:Setting the default help home page
Current Time: Fri Dec 13 22:02:35 GMT 2024
Powered by FUDForum. Page generated in 0.04204 seconds
