Re: "No suitable provider" error with svn provider [message #556063 is a reply to message #556027] |
Mon, 30 August 2010 17:17 |
Do you have all target.xxx set to '*' ? Even target.nl?
- thomas
On 08/30/2010 05:24 PM, Tomsen wrote:
> Hi all,
> I try to adapt the Buckminster Mailapp Buckminster files to my
> application and keep getting the following errors when trying to
> "Resolve to Wizard" my developer.cquery
> !ENTRY org.eclipse.buckminster.core 4 293 2010-08-30 14:57:08.046
> !MESSAGE ERROR [0001] : No suitable provider for component
> de.softproject.xe.standalone.feature:eclipse.feature was found in
> resourceMap
> file:/C:/SVN/MAIN/Products/Eclipse-RCP/XSLEasy/trunk/de.soft project.xe.standalone.releng/eclipse.rmap
> searchPath de.softproject.xe
> ERROR [0001] : Filter
> (&(target.nl=en)(target.os=win32)(target.ws=win32)(|(tar get.arch=ia64)(target.arch=ia64_32)(target.arch=x86)(target. arch=x86_64)))
> does not match the current property set
> Not sure what part the last line plays. I think I have a proper match
> for feature de.softproject.xe.standalone.feature in my rmap which looks
> like
> <rm:locator pattern="^de\.softproject\.xe(\..+)?"
> searchPathRef="de.softproject.xe"/>
> <rm:searchPath name="de.softproject.xe">
> <rm:provider componentTypes="osgi.bundle,eclipse.feature,buckminster"
> readerType="svn"
> mutable="true"
> source="true">
> <rm:uri
> format=" https://{0}:{1}@80.xxx.xxxx.xxx/svn/MAIN/Products/Eclipse-RC P/XSLEasy/trunk/{2}">
> <bc:propertyRef key="svn.user"/>
> <bc:propertyRef key="svn.password"/>
> <bc:propertyRef key="buckminster.component"/>
> </rm:uri>
> </rm:provider>
> </rm:searchPath>
> I have Target.* set to meaningful values.
Re: "No suitable provider" error with svn provider [message #556223 is a reply to message #556199] |
Tue, 31 August 2010 11:36 |
Hi Thomas,
On 08/31/2010 12:29 PM, Tomsen wrote:
> Quote:
> No, I have a buckminster.properties which sets target.arch, target.os
> and target.ws.
OK, so then the reported error makes sense.
> target.os=win32
> target.ws=win32
> target.arch=x86
> I don't set target.nl. Should I?
In this case, yes.
> Is there any way to trace settings Buckminster sees?
Not beyond what it has already reported but the info is in the output
from your original post:
With this line, Buckminster tells you that the component was rejected
because the filter didn't match. The problem in this case is that the
filter requires target.nl=en. Setting target.nl to '*' will make this
filter return true since '*' is a substitute for all possible values.
HTH,
- thomas
Re: "No suitable provider" error with svn provider [message #556392 is a reply to message #556388] |
Wed, 01 September 2010 07:12 |
On 09/01/2010 09:00 AM, Tomsen wrote:
> Thomas,
> thx. I added
> <cq:property key="target.nl" value="*"/>
> to my developer.cquery and it magically worked ...
> I am puzzled now because I simply adapted the developer.cquery from the
> mailapp tutorial to my needs and this prop isn't contained there. When I
> try "Resolve to Wizard" for the developer.cquery in the mailapp case it
> works without this error ... any ideas why this might be the case?
The mailapp tutorial will not make an attempt to resolve features that are targeted for specific languages so there's no
need to set the target.nl property. Your app however, requires the 'de.softproject.xe.standalone.feature' and this
feature is obviously only available for specific languages. Hence the need to provide a language of choice (using
target.nl=en) or specify that any comparison against this property should yield true (using target.nl=*)
No magic really, Buckminster is just honoring the rules expressed in the feature.
Thomas Hallgren
FUDForum. Page generated in 0.02194 seconds
