Home » Archived » B3 » multiple versions of a feature could not be mirrored
multiple versions of a feature could not be mirrored [message #555946] Mon, 30 August 2010 11:02 Go to next message
Lars Fischer is currently offline Lars FischerFriend
I would like to mirror the Eclipse RAP Runtime site
(http://download.eclipse.org/rt/rap/1.3/runtime/) using B3 aggregator.
This site contains the feature
"org.eclipse.rap.runtime.sdk.feature.group" in two versions (1.3.0 and
1.3.1) If I use this update site inside an eclipse target platform
definition (".target"-file) I can choose between these two versions.
I created an aggregator model with one contribution containing the rap
repository. Nothing more.
When I run the aggregator with this model I get a new p2 mirror. But
when I try to use this as source inside my .target definition, there is
only version 1.3.1 contained.
I tried to explicit map the two versions by using a custom category, but
there is still only the higher version visible.
Where is my mistake? How can I create a mirror containing both versions
of the feature?
Lars
Re: multiple versions of a feature could not be mirrored [message #633500 is a reply to message #555946] Mon, 18 October 2010 09:09 Go to previous messageGo to next message
> of the feature?
I still would like to see all versions of the features with all needed
bundles in the resulting mirror.
I would be very happy, if someone could please tell me, if this is
possible and how to do this.
Kind regards,
Lars
Re: multiple versions of a feature could not be mirrored [message #658461 is a reply to message #555946] Tue, 08 March 2011 15:36 Go to previous messageGo to next message
Matt Biggs is currently offline Matt BiggsFriend
Member
I've got the same problem with the orbit repository.
If i add the entire repository, i would expect it to pull down all versions of the plug-ins but instead i only get 1 version.
Eg. if i combine helios site and orbit, org.apache.commons.lang v2.3.0 is pulled down and v2.4.0 is ignored despite it existing on the orbit repository.
Re: multiple versions of a feature could not be mirrored [message #658473 is a reply to message #658461] Tue, 08 March 2011 16:16 Go to previous messageGo to next message
Stephane Bouchet is currently offline Stephane BouchetFriend
Same problem here, i raised a enhancement request for such a request,
because b3 is only used as an aggregator, not a mirror application
https://bugs.eclipse.org/bugs/show_bug.cgi?id=338409
> repository.
Stéphane Bouchet, OBEO
Re: multiple versions of a feature could not be mirrored [message #688403 is a reply to message #658473] Fri, 24 June 2011 16:05 Go to previous message
Terran Gilman is currently offline Terran GilmanFriend
Member
I have the same need.
http://www.eclipse.org/forums/index.php/t/212568/
Previous Topic:Merging two p2 repositories regardless of contents
Next Topic:(no subject)
Current Time: Wed Oct 04 01:18:38 GMT 2023
Powered by FUDForum. Page generated in 0.03577 seconds
