Re: Can't display Chart or Image in Excel export [message #555669 is a reply to message #555481] |
Fri, 27 August 2010 14:08 |
I do not know of any other open source xls emitters. I know there is a
bugzilla entry to add the chart to the BIRT xls emitter. Also Actuate
has a commercial emitter that is very good.
Jason
On 8/26/2010 1:57 PM, YANG wrote:
> Thanks a lot for your reply.
> Well, I've tried the Tribix Emitter and not satisfied with its export
> result in Excel: no respect for the Worksheet Rows and uses different
> font which I found not as good as BIRT's.
> Do you know any other Emitter who does a perfect job?
Re: Can't display Chart or Image in Excel export [message #556080 is a reply to message #555707] |
Mon, 30 August 2010 17:44 |
I believe you can a commercial version of the engine, but I think you
will have to contact Actuate:
http://www.birt-exchange.com/be/news-events/contact-us/
Also remember that this is available in Actuate 11 which is releasing in
September.
Jason
On 8/27/2010 2:00 PM, YANG wrote:
> Thanks again for your reply.
> I've tested the Actuate BIRT Report Designer Pro. It does work fine.
> But if I purchase it, how can I use its emitters in any standalone Java
> application.
> Like the BIRT open source Eclipse plugin, it has its own Runtime engine
> librabies, but when it comes to the Actuate BIRT, they kinda use a
> different prototype for the Excel Emitter, so when I try to use it as
> the same way as Tribix Emiitter, there are exceptions.
> Did I forget sth important or there is another proper way to combine
> Actuate BIRT and Eclipse?
FUDForum. Page generated in 0.02112 seconds
