Home » Modeling » M2T (model-to-text transformation) » [Acceleo] How to determine why a template isn't called
[Acceleo] How to determine why a template isn't called [message #554742] |
Tue, 24 August 2010 09:48 |
Originally posted by: templth.yahoo.fr
I developed a template that seems correct but nothing happens when
launching generation (from Acceleo Application in Run Configurations).
It seems that my parameter of my template doesn't match to any element
in the model... At least one should match... Is there a way to see
traces from the Acceleo engine or simulate execution?
Note that I use a metamodel with several packages and I declare several
packages in the generate attribute of the module...
Thanks very much for your help!
Thierry
Re: [Acceleo] How to determine why a template isn't called [message #554883 is a reply to message #554742] |
Tue, 24 August 2010 15:38 |
If your template was not the starting point of your generation, you could see why the parameters are not matching, I didn't thought of your template as the starting point of your generation, sorry.
1- Does it sill has its main comment : [comment @main/] ? (even if I'm pretty sure that an error would appear if you tried to launch a generation without it)
2- Do you have modified the generated java class ? (if yes, you can delete it and save your acceleo module again, the java class will be generated and then try again)
3- Do you have the same problem with a very simple template and model, if yes can you show me the template, the model and your launch configuration ? Because I tried to recreate the problem and for me it works. It would be very helpful in order to track the problem.
Stephane Begaudeau, Obeo
Re: [Acceleo] How to determine why a template isn't called [message #555145 is a reply to message #554883] |
Wed, 25 August 2010 15:09 |
Hello Stéphane,
No problem! Your hints help me a lot!
It seems that the manual registering of my metamodel within my current
Eclipse instance isn't enough... As a matter of fact, when trying to
create the acceleo project, my uri doesn't appear in the list of
"Metamodel URI"... Moreover, if I run a new Eclipse instance and create
in it an acceleo project with my template, everything works fine and the
code is generated.
For information, I register the metamodel like this:
EPackage architecturePackage = ArchitecturePackage.eINSTANCE;
EPackage.Registry.INSTANCE.put(architecturePackage.getNsURI( ),
architecturePackage);
Any idea?
Thierry
Re: [Acceleo] How to determine why a template isn't called [message #555277 is a reply to message #555145] |
Thu, 26 August 2010 07:46 |
Well if it is working with another instance of Eclipse but not with the current instance, the problem is definitely coming from the registration process. That's a common problem when working with EMF. To solve this problem, I think that you have 5 solutions:
1- you can work with another Eclipse instance (yes I know, it's painful...)
2- you can try to load your model by creating a new EMF project [not an empty one] because the new EMF project wizard has an option to load your metamodel. It worked for me a few time.
3- you can use the relative path to your model instead of its URI (I've learned that trick this morning from the original creator of Acceleo), I've tested it and it worked. Here is a screenshot of how to do it: Click me !. The key here is the [module generate('platform:/resource/org.eclipse.acceleo.test/model/ MetaTest.ecore')/] instead of [module generate('http://myURI.com')/]
4- you can use the normal URI of your metamodel with your metamodel in another project or anywhere else if the project that contains your metamodel is a dependency of your Acceleo project and if that metamodel is registered thanks to EMF extention point (org.eclipse.emf.ecore.dynamic_package). I've tested it and it also worked (I've also learned that trick this morning ). Here are two screenshots to see how it's done : n°1 and n°2
5- you can try to register your metamodel by yourself with a bit of Java, like it is described here.
So with this solution, I have created another project with my meta model, registered thanks to the EMF extension point and this new project is a dependency of my Acceleo project (screenshot 1). And then I can use it in my Acceleo project and it works as you can see it in the screenshot 2.
Well, I think you have here all the available solutions (and I've learned two great solutions while searching this for you )
[Updated on: Thu, 26 August 2010 07:48] Report message to a moderator
Re: [Acceleo] How to determine why a template isn't called [message #556672 is a reply to message #555277] |
Thu, 02 September 2010 09:48 |
mami Messages: 3 Registered: July 2010 |
Junior Member |
It's just about the registration process, me too I was obliged to work on another eclipse instance if i wanted create my Acceleotemplates, but not anymore.
So, if you want the metamodel to be recognized in the current instance (without launching another), you must add the plugin containing this metamodel to eclipse as follows:
- Go to "File" -> "Export..."
- In the Export wizard, go to "Plug-in Developmnent", select "Deployable plug-ins and fragments" and clic "Next",
- In the next page of wizard, select the plug-in you want deploy, check "Install into host. Repository" and clic "Finish".
Restart your eclipse and verify that the plug-in has been added (Eclipse -> About Eclipse SDK -> Installation Details -> Plug-ins)
If you follow the steps above, you can see appear the Ns URI of your metamodel in the URI list.
Mami
Current Time: Thu Apr 25 20:34:13 GMT 2024
Powered by FUDForum. Page generated in 0.03583 seconds
