Home » Modeling » Epsilon » [EOL] Help with GmfGraph Navigation.
Re: [EOL] Help with GmfGraph Navigation. [message #554475 is a reply to message #554474] |
Mon, 23 August 2010 11:09 |
Dimitrios Kolovos Messages: 1776 Registered: July 2009 |
Hi Toni,
Unfortunately, there's no auto-completion in the EOL editor. However,
the EPackage registry view [1] and Exeed [2] should help you figure out
the right expression.
[1] http://eclipse.org/gmt/epsilon/doc/articles/epackage-registr y-view/
[2] http://eclipse.org/gmt/epsilon/doc/articles/inspect-models-e xeed/
Dimitris
Toñi Reina Quintero wrote:
> I'm writing a ECore2GMF.eol file to polish my editor, as it is
> explained in the EuGENia: Polishing your GMF editor blog Entry
> ( http://epsilonblog.wordpress.com/2009/06/15/eugenia-polishin g-your-gmf-editor/).
> In the tutorial font styles are changed, but I'd like to change font
> color. I suppose that most of the expressions that start with GmfGraph!
> are ways to query and navigate through the GmfGraph model created for my
> editor. I also suppose that the expression should be something like
> mylabelLabel.font.color, but the autocompletion does not work, and I
> can't obtaine the font properties easily.
> I would appreciate some help for finding these properties. I think the
> best way is by using the own .eol editor and autocompletion, but if this
> is not possible, it would help accesing to the GmfGraph ecore metamodel.
> Thanks in advance,
> Toñi
Re: [EOL] Help with GmfGraph Navigation. [message #554514 is a reply to message #554475] |
Mon, 23 August 2010 13:04 |
Toñi Reina Messages: 209 Registered: July 2009 |
Thanks a lot,
El 23/08/2010 13:09, Dimitris Kolovos escribió:
> Hi Toni,
> Cheers,
> Dimitris
>> Hi,
>> GmfGraph! are ways to query and navigate through the GmfGraph model
>> created for my editor. I also suppose that the expression should be
>> something like mylabelLabel.font.color, but the autocompletion does
>> not work, and I can't obtaine the font properties easily.
>> this is not possible, it would help accesing to the GmfGraph ecore
>> metamodel.
>> Thanks in advance,
>> Toñi
Re: [EOL] Help with GmfGraph Navigation. [message #593128 is a reply to message #554474] |
Hi Toni,
Dimitris
> Thanks in advance,
> Toñi
Re: [EOL] Help with GmfGraph Navigation. [message #593138 is a reply to message #554475] |
Thanks a lot,
> Hi Toni,
> Cheers,
> Dimitris
>> Hi,
>> metamodel.
>> Thanks in advance,
>> Toñi
Current Time: Thu Apr 25 19:47:43 GMT 2024
Powered by FUDForum. Page generated in 0.03314 seconds
