Hudson plugin fails to install buckminster [message #554466] |
Mon, 23 August 2010 10:04 |
Peter Kullmann Messages: 240 Registered: July 2009 |
Hi, I have the following error when installing buckminster through the
hudson plugin:
Unpacking
http://download.eclipse.org/tools/buckminster/products/direc tor_latest.zip
to /home/svw/.hudson/tools/Buckminster_3.6 on Hudson
[Buckminster_3.6] $
/home/svw/.hudson/tools/Buckminster_3.6/director/director -vm
/home/svw/.hudson/tools/JDK-5.0/bin/java -d
/home/svw/.hudson/tools/Buckminster_3.6/buckminster -p Buckminster -r
"http://download.eclipse.org/tools/buckminster/headless-3.6,
http://download.eclipse.org/tools/buckminster/headless-3.6/,
http://download.cloudsmith.com/buckminster/external-3.6" -installIU
"org.eclipse.equinox.p2.director.feature.feature.group,
org.eclipse.buckminster.psf.feature.feature.group,
org.eclipse.buckminster.emma.headless.feature.feature.group,
org.eclipse.buckminster.pde.headless.feature.feature.group,
org.eclipse.buckminster.subclipse.headless.feature.feature.g roup,
org.eclipse.buckminster.maven.headless.feature.feature.group ,
org.eclipse.buckminster.cmdline.product,
org.eclipse.buckminster.core.headless.feature.feature.group,
org.eclipse.buckminster.git.headless.feature.feature.group,
org.eclipse.buckminster.cvs.headless.feature.feature.group"
Installing org.eclipse.equinox.p2.director.feature.feature.group
1.2.1.v20100819-2107.
Installing org.eclipse.buckminster.psf.feature.feature.group 1.0.0.r11564.
Installing org.eclipse.buckminster.emma.headless.feature.feature.group
0.9.0.r11564.
Installing org.eclipse.buckminster.pde.headless.feature.feature.group
1.2.1.r11567.
Installing
1.1.0.r11440.
Installing org.eclipse.buckminster.maven.headless.feature.feature.group
1.2.0.r11564.
Installing org.eclipse.buckminster.cmdline.product 1.2.1.r11564.
Installing org.eclipse.buckminster.core.headless.feature.feature.group
1.3.1.r11564.
Installing org.eclipse.buckminster.git.headless.feature.feature.group
1.0.360.r11564.
Installing org.eclipse.buckminster.cvs.headless.feature.feature.group
1.1.0.r11564.
Installation failed.
Cannot complete the install because one or more required items could not
be found.
Software being installed: Buckminster - Team Project Set (PSF) support
1.0.0.r11564 (org.eclipse.buckminster.psf.feature.feature.group
1.0.0.r11564)
Missing requirement: Buckminster - Team Project Set (PSF) support
1.0.0.r11564) requires
'org.eclipse.buckminster.core.feature.feature.group 0.0.0' but it could
not be found
Application failed, log file location:
/home/svw/.hudson/tools/Buckminster_3.6/director/configurati on/1282402427843.log
Peter
Re: Hudson plugin fails to install buckminster [message #554508 is a reply to message #554507] |
Mon, 23 August 2010 12:50 |
I'm currently investigating the cause of this. I'll get back to you when I know more.
- thomas
On 08/23/2010 02:45 PM, Johannes Utzig wrote:
> Hi Peter,
> I noticed this problem too. Something about the feature grouping has
> changed, but I don't know what, yet.
> As a workaround I will remove the psf feature tonight so the plugin will
> no longer try to install it (I hope you don't need that feature...).
> It may take a day or so until your hudson instance picks up the change
> in the feature list.
> @Thomas, if you happen to read this, do you know where the problem comes
> from? This is what the plugin currently tries to install when 3.6 is
> selected:
> org.eclipse.buckminster.subclipse.headless.feature (from cloudsmith)
> Is the psf feature still maintained, or should I remove it for good in
> the 3.6 list?
> Best regards,
> Johannes
Re: Hudson plugin fails to install buckminster [message #554705 is a reply to message #554580] |
Tue, 24 August 2010 07:11 |
Johannes Utzig Messages: 329 Registered: July 2009 |
Hi Peter,
Am 23.08.2010 17:32, schrieb Peter Kullmann:
> I had to setup a temporary buckminster install (without the psf feature)
> in order to keep my builds running. But as soon as the new plugin will
> be available I will switch over.
Sorry, you missunderstood me. I did not release a new version of the
plugin, I only updated the file that's telling the plugin which features
to install into a fresh buckminster. This file is fetched from
hudson-ci.org, so it will get distributed automatically and you don't
need to update anything manually.
http://hudson-ci.org/updates/hudson.plugins.buckminster.Buck minsterInstallation.BuckminsterInstaller.json
What I meant with 'takes 6 hours to 2 days' is
1. The time the hudson infrastructure needs to push the changes in
subversion to the URL above
2. The time your running hudson waits before checking for changes in the
update files
The file was updated pretty quickly yesterday so the installation should
work again for you. If not, it's a matter of a few hours before your
hudson checks for updates of the installer files again.
> BTW: Cool plugin, thanks for it!
Glad you like it, you are welcome :)
Johannes
FUDForum. Page generated in 0.04153 seconds
