Connection profile store location [message #554420] |
Mon, 23 August 2010 05:15 |
Kavitha Messages: 10 Registered: August 2010 |
Dear friends,
I am designing reports on Windows and for development purpose we are just using
Run --> View Report ->In WebWiewer/PDF for testing.For each report we are creating data source with db connection.When we changed db for production.Now I have to change in all my reports to modify the connection information in them.
So hard coding connection info in rptdesign file seems to be bad idea and I want to change this by the way.So I created Connection profile XML and using this file in data source Connection Profile.
In my rptdesign file, XML source shows
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc.dbprofile " name="SampleDS" id="2178">
<list-property name="privateDriverProperties">
<ex-property>
<name> org.eclipse.datatools.connectivity.oda.profile.db.provider.i d </name>
<value>org.eclipse.datatools.enablement.oracle.connectionProfile </value>
</ex-property>
</list-property>
<property name="OdaConnProfileName">New Oracle(0)</property>
<property name="OdaConnProfileStorePath">D:\workspace\reports\WebContent\Oracle_Profile </property>
</oda-data-source>
</data-sources>
how to change OdaConnProfileStorePath to relative path?
While googling i got something like The Javascript expression can refer to a BIRT config[] variable. For
example,
config[ "birt.viewer.working.path" ] + "../../data/myData.csv" .When i gave this script in data source --> property binding --> connection profile store url.I got some error like ,
+ Error evaluating Javascript expression. Script engine error: birt.viewer.resource.path not found
Script source: <inline>, line: 0, text:
config[ "birt.viewer.resource.path" ] + "/Oracle_Profile"
Please Provide me steps what should I do to be able to use this file by my reports? Please Help me i am in crucial stage.
Kavitha
[Updated on: Mon, 23 August 2010 05:17] Report message to a moderator
Re: Connection profile store location [message #554594 is a reply to message #554420] |
Mon, 23 August 2010 16:06 |
You can set the location also in the beforeOpen script of the dataset like:
this.setExtensionProperty("OdaConnProfileStorePath",
"c:/work/styles/mysqlclassic.txt");
To make it relative use a combination of these scripts:
var rp =
reportContext.getHttpServletRequest().getSession().getServle tContext().getRealPath( "/MyConnectionProfiles");
if( rp != null ){
this.setExtensionProperty("OdaConnProfileStorePath",rp);
You can get an init parameter like:
var mrp =
reportContext.getHttpServletRequest().getSession().getServle tContext().getInitParameter( "BIRT_RESOURCE_PATH");
Jason
On 8/23/2010 1:15 AM, Kavitha wrote:
> Dear friends,
> just using
> <data-sources>
> <oda-data-source
> name="SiteMonVisitsDS" id="2178">
> <ex-property>
> </name>
> </ex-property>
> </list-property>
> <property
> </property>
> </oda-data-source>
> </data-sources>
> example,
> Kavitha
Re: Connection profile store location [message #554675 is a reply to message #554674] |
Tue, 24 August 2010 04:11 |
Kavita,
Can you add this to your script:
> var rp = reportContext.getHttpServletRequest().getSession().getServle
> tContext().getRealPath( "/Oracle_Profile");
> if( rp != null ){
importPackage( Packages.java.io );
out = new PrintWriter( new FileWriter( "c:/temp/events.txt", true ) );
out.println( "rp = " + rp);
out.close();
And see if rp actually got set?
Jason
On 8/24/2010 12:01 AM, Kavitha wrote:
> Hi Jason,
> Thanks for the reply.
> I have given like this,
> if( rp != null ){
> in connection Profile Store URL of data source.On ping i got below
> exception.What could be the problem?
> Oracle_Profile is there in my workspace.
> org.eclipse.datatools.connectivity.oda.OdaException: Unable to find the
> connection profile referenced by the data source connection properties.
> at org.eclipse.birt.report.data.oda.jdbc.dbprofile.impl.Connect
> ion.open(Connection.java:97)
> ion.open(Connection.java:57)
> at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaCo
> nnection.open(OdaConnection.java:238)
> at org.eclipse.datatools.connectivity.oda.profile.OdaConnection
> Wrapper.open(OdaConnectionWrapper.java:209)
> at org.eclipse.datatools.connectivity.oda.profile.OdaConnection Wrapper.
> <init>(OdaConnectionWrapper.java:59)
> Factory.createConnection(OdaConnectionFactory.java:26)
> at org.eclipse.datatools.connectivity.internal.ConnectionFactor
> yProvider.createConnection(ConnectionFactoryProvider.java:83 )
> at org.eclipse.datatools.connectivity.internal.ConnectionProfil
> e.createConnection(ConnectionProfile.java:355)
> at org.eclipse.datatools.connectivity.ui.PingJob.createTestConn
> ection(PingJob.java:76)
> at org.eclipse.datatools.connectivity.oda.design.internal.ui.Da
> taSourceEditorPageCore$1.run(DataSourceEditorPageCore.java:6 08)
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
> at org.eclipse.datatools.connectivity.ui.wizards.ProfileDetails
> PropertyPage.testConnection(ProfileDetailsPropertyPage.java: 98)
> PropertyPage$1.widgetSelected(ProfileDetailsPropertyPage.jav a:80)
> at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe
> ner.java:228)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3880)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3473)
> at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
> at org.eclipse.jface.window.Window.open(Window.java:801)
> at org.eclipse.birt.report.designer.ui.dialogs.BaseDialog.open(
> BaseDialog.java:110)
> at org.eclipse.birt.report.designer.data.ui.actions.EditDataSou
> rceAction.doAction(EditDataSourceAction.java:68)
> at org.eclipse.birt.report.designer.internal.ui.views.actions.A
> bstractElementAction.run(AbstractElementAction.java:70)
> at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
> at org.eclipse.jface.action.ActionContributionItem.handleWidget
> Selection(ActionContributionItem.java:584)
> at org.eclipse.jface.action.ActionContributionItem.access$2(Act
> ionContributionItem.java:501)
> at org.eclipse.jface.action.ActionContributionItem$5.handleEven
> t(ActionContributionItem.java:411)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
> at org.eclipse.core.databinding.observable.Realm.runWithDefault
> (Realm.java:332)
> at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work
> bench.java:493)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at org.eclipse.ui.internal.ide.application.IDEApplication.start
> (IDEApplication.java:113)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips
> eAppHandle.java:194)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher
> .runApplication(EclipseAppLauncher.java:110)
> .start(EclipseAppLauncher.java:79)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS
> tarter.java:368)
> tarter.java:179)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
> Thank you,
> Kavitha
Re: Connection profile store location [message #555152 is a reply to message #554978] |
Wed, 25 August 2010 15:50 |
I assume this means rp is null.
Can you try this:
Can you try this script:
rp =
reportContext.getHttpServletRequest().getSession().getServle tContext().getRealPath( "/Oracle_Profile");
if( rp != null ){
}else{
out.println(" rp is null " );
myresourcefolder = reportContext.getDesignHandle().getResourceFolder()
out.println("resource folder is set to "+myresourcefolder);
out.close();
This will check to see if we have the resource folder an we can use it
instead of the path you provided above. Also notice that I removed the
var keyword off the variable rp. This will make it global.
Jason
On 8/24/2010 11:57 PM, Kavitha wrote:
> Its not displaying anything
Re: Connection profile store location [message #555457 is a reply to message #555243] |
Thu, 26 August 2010 16:26 |
Attached is my example. I use mysql and tomcat.
The resource folder is set in the web.xml like:
<!-- Resource location directory. Defaults to ${birt home} -->
<context-param>
<param-name>BIRT_RESOURCE_PATH</param-name>
<param-value>myresources</param-value>
</context-param>
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.5.2.v20100208 Build <2.5.2.v20100210-0630></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">96</property>
<data-sources>
<oda-data-source
name="mysqlclassic" id="125">
<method name="beforeOpen"><![CDATA[if(
!reportContext.getHttpServletRequest().getAttribute("attributeBean ").isDesigner()
//this.setExtensionProperty("OdaConnProfileStorePath",
out = new PrintWriter( new FileWriter( "c:/test9/conevents.txt", true ) );
//rp =
//if( rp != null ){
//out.println( "rp = " + rp);
//this.setExtensionProperty("OdaConnProfileStorePath",rp);
//}else{
//out.println(" rp is null " );
out.close();
myresourcefolder+"/mysqlclassic.txt");
]]></method>
<ex-property>
<value>org.eclipse.datatools.enablement.mysql.connectionProfile </value>
</ex-property>
</list-property>
<property name="OdaConnProfileName">mysqlclassic</property>
<property
name="OdaConnProfileStorePath">c:\work\styles\mysqlclassic.txt </property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.dbprofile.sqbDataSet "
name="Data Set" id="126">
<list-property name="columnHints">
<structure>
<property name="columnName">orderNumber</property>
<text-property
name="displayName">orderNumber</text-property>
</structure>
<structure>
<property name="columnName">productCode</property>
<text-property
name="displayName">productCode</text-property>
</structure>
<structure>
<property name="columnName">quantityOrdered</property>
<text-property
name="displayName">quantityOrdered</text-property>
</structure>
<structure>
<property name="columnName">priceEach</property>
<text-property
name="displayName">priceEach</text-property>
</structure>
<structure>
<property name="columnName">orderLineNumber</property>
<text-property
name="displayName">orderLineNumber</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">orderNumber</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">productCode</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">quantityOrdered</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">priceEach</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">orderLineNumber</property>
</structure>
</list-property>
</structure>
<property name="dataSource">mysqlclassic</property>
<structure>
<property name="nativeName">orderNumber</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">productCode</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">quantityOrdered</property>
</structure>
<structure>
<property name="nativeName">priceEach</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">orderLineNumber</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[SELECT *
FROM `mydb`.`orderdetails`
]]></xml-property>
<structure name="designerState">
<property name="version">1.0</property>
<property name="stateContentAsString"><?xml
version="1.0" encoding="UTF-8"?>
<SQLQueryBuilder editorInputType="SQLBuilderStorageEditorInput"
name="Data Set" version="1.0">
<SQLStatement>SELECT *&#x0A; FROM
`mydb`.`orderdetails`&#x0A;</SQLStatement>
<connInfo>MySQL_5.1.0:mysqlclassic:mydb:root</connInfo >
<omitSchemaInfo>false:true:</omitSchemaInfo>
<editorInputUsageOptions>useWindowState=true</editorInputUsageOptions >
<windowState height="478" version="1.0" width="687">
<control height="145" isHideable="true" isVisible="true"
name="SQLSourceViewer" width="660"/>
<control height="150" isHideable="true" isVisible="true"
name="DesignViewer" width="673"/>
name="GraphControl" width="665"/>
<control height="149" isHideable="true" isVisible="false"
name="OutlineViewer" width="198"/>
</windowState>
</SQLQueryBuilder></property>
</structure>
<xml-property name="designerValues"><![CDATA[<?xml
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>orderNumber</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>11</design:precision>
<design:scale>0</design:scale>
<design:nullability>NotNullable</design:nullability>
<design:uiHints>
<design:displayName>orderNumber</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>orderNumber</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>productCode</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>productCode</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>productCode</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>quantityOrdered</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>quantityOrdered</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>quantityOrdered</design:label>
<design:attributes>
<design:name>priceEach</design:name>
<design:position>4</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:precision>22</design:precision>
<design:scale>31</design:scale>
<design:uiHints>
<design:displayName>priceEach</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>priceEach</design:label>
<design:displaySize>22</design:displaySize>
<design:attributes>
<design:name>orderLineNumber</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>5</design:nativeDataTypeCode>
<design:precision>6</design:precision>
<design:uiHints>
<design:displayName>orderLineNumber</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>orderLineNumber</design:label>
<design:displaySize>6</design:displaySize>
</design:resultSetColumns>
<design:criteria>
<design:rowOrdering/>
</design:criteria>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="127">
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<text-property
<expression name="expression"
type="javascript">dataSetRow["orderNumber"]</expression >
</structure>
<structure>
<text-property
type="javascript">dataSetRow["productCode"]</expression >
</structure>
<structure>
<text-property
type="javascript">dataSetRow["quantityOrdered"]</expression >
</structure>
<structure>
<text-property
type="javascript">dataSetRow["priceEach"]</expression>
</structure>
<structure>
<text-property
type="javascript">dataSetRow["orderLineNumber"]</expression >
</structure>
</list-property>
<column id="156"/>
<column id="157"/>
<column id="158"/>
<column id="159"/>
<column id="160"/>
<header>
<row id="128">
<cell id="129">
<label id="130">
<text-property
name="text">orderNumber</text-property>
</label>
</cell>
<cell id="131">
<label id="132">
<text-property
name="text">productCode</text-property>
</label>
</cell>
<cell id="133">
<label id="134">
<text-property
name="text">quantityOrdered</text-property>
</label>
</cell>
<cell id="135">
<label id="136">
<text-property
name="text">priceEach</text-property>
</label>
</cell>
<cell id="137">
<label id="138">
<text-property
name="text">orderLineNumber</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="139">
<cell id="140">
<data id="141">
<property
name="resultSetColumn">orderNumber</property>
</data>
</cell>
<cell id="142">
<data id="143">
<property
name="resultSetColumn">productCode</property>
</data>
</cell>
<cell id="144">
<data id="145">
<property
name="resultSetColumn">quantityOrdered</property>
</data>
</cell>
<cell id="146">
<data id="147">
<property
name="resultSetColumn">priceEach</property>
</data>
</cell>
<cell id="148">
<data id="149">
<property
name="resultSetColumn">orderLineNumber</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="150">
<cell id="151"/>
<cell id="152"/>
<cell id="153"/>
<cell id="154"/>
<cell id="155"/>
</row>
</footer>
</table>
</body>
</report>
On 8/26/2010 12:40 AM, Kavitha wrote:
> On DataSource Test Connection i got below exception,
> ner.java:228)
> (Realm.java:332)
> bench.java:493)
> tarter.java:368)
> tarter.java:179)
> Please can you send me a sample report
Re: Connection profile store location [message #556069 is a reply to message #555911] |
Mon, 30 August 2010 17:24 |
Kavitha,
If you use the standard JDBC connection you can change any of the
properties at runtime using script or property binding. I am not
certain why the profile store method is not working for you. Did you
take a look at my example?
Jason
On 8/30/2010 4:22 AM, Kavitha wrote:
> Can i create dynamic data source and set Property from the property file
> to resolve my problem? :(
Re: Connection profile store location [message #556962 is a reply to message #554420] |
Fri, 03 September 2010 11:29 |
I don't know why its not working for me or i am doing some thing wrong.
Come to dynamic data source creation,
I have created a JDBC data source & given default development db and in the report beforeFactory i given like,
importPackage(Packages.java.util.Properties);
importPackage(Packages.java.io);
ds = reportContext.getDesignHandle().getDesign().findDataSource("Data Source");
property = new Properties();
property.load(new FileInputStream(reportContext.getDesignHandle().getResourceF older()+ "/Oracle_Profile"));
ds.setProperty( "odaDriverClass",property.getValue("odaDriverClass"));
ds.setProperty( "odaURL", property.getValue("odaURL"));
ds.setProperty( "odaUser", property.getValue("odaUser"));
ds.setProperty( "odaPassword", property.getValue("odaPassword"));
reportContext.getDesignHandle().getDesign().add(ds);
In while running report at run time i am reading from property file which has different db property.I am getting exceptions like below,
org.eclipse.birt.report.engine.api.EngineException: There are errors evaluating script "importPackage(Packages.java.util.Properties); importPackage(Packages.java.io); ds = reportContext.getDesignHandle().getDesign().findDataSource("Data Source"); property = new Properties(); property.load(new FileInputStream(reportContext.getDesignHandle().getResourceF older()+ "/Oracle_Profile")); ds.setProperty( "odaDriverClass",property.getValue("odaDriverClass")); ds.setProperty( "odaURL", property.getValue("odaURL")); ds.setProperty( "odaUser", property.getValue("odaUser")); ds.setProperty( "odaPassword", property.getValue("odaPassword")); ": Function importPackage must be called with a package; had "[JavaClass java.util.Properties]" instead. (/report/method[@name="beforeFactory"]#1)
what could be the problem??????
Thank you,
Kavitha
Re: Connection profile store location [message #557015 is a reply to message #556962] |
Fri, 03 September 2010 15:25 |
This line:
should be
importPackage(Packages.java.util);
Jason
On 9/3/2010 7:29 AM, Kavitha wrote:
> Source");
> property.load(new
> Thank you,
> Kavitha
Re: Connection profile store location [message #557201 is a reply to message #554420] |
Mon, 06 September 2010 04:55 |
Hi Jason,
I am getting some exception like below,
org.eclipse.birt.report.engine.api.EngineException: An exception occurred during processing. Please see the following message for details: Cannot open the connection for the driver: org.eclipse.birt.report.data.oda.jdbc. org.eclipse.birt.report.data.oda.jdbc.JDBCException: Missing properties in Connection.open(Properties).
I created data source and i am using dev mode connections. before factory method of design i am reading connections from property file for production mode connections.
i have added one table and while executing i am getting above exception.
I am having few doubts about connection profile property binding please can you clear it.
1.While creating connection profile data source by default we need to give connection file name with out giving default connection file data source will not get created. how can i change it to accept dynamic file name.
[Updated on: Mon, 06 September 2010 10:46] Report message to a moderator
Re: Connection profile store location [message #557460 is a reply to message #557201] |
Tue, 07 September 2010 13:54 |
I did not see where you set the
OdaConnProfileStorePath property in your script.
Jason
On 9/6/2010 12:56 AM, Kavitha wrote:
> Hi Jason,
FUDForum. Page generated in 0.04614 seconds
