cygwin and CDT compatibility issue [message #554415] |
Sun, 22 August 2010 22:51 |
sorrentino Messages: 2 Registered: August 2010 |
Junior Member |
I hope that I wrote in the right section.
Hi every one,I'm very,very sorry,but I don't speak english fluently.
I have an issue compatibility with cygwin and Eclipse 3.5 yoxos.
I have a Windows Vista 32 bit OS,and Until a month ago,
I could build and compile my files.c with cygwin 2.7.2 and Eclipse.
A week ago I Realized that files.c were not built and executed.
I checked all the configuration parameters:
1)Tool Chain Editor-> Cygwin GCC
Current Builder-> Gnu Make Builder(default) and CDT Internal Builder(I tried both builders).
2)Environment-> PATH C:\cygwin\bin
3)Path & Symbols -> GNU C C:\cygwin\usr\include
C:\cygwin\usr\include\w32api
C:\lib\gcc\i686-pc-cygwin\3.4.4\include or
C:\lib\gcc\i686-pc-cygwin\4.3.4\include
C:\lib\gcc\i686-pc-cygwin\4.3.4\include-fixed
Whenever I try to compile a file.c,cygwin crashes(APPCRASH).
I reinstalled cygwin many times and I downloaded all the tools
useful for programming in C, including gcc.
If I use the Cygwin Bash Shell, the files.c are compiled and run correctly.
Eclipse works very fine with MinGW and the jdk.
I have no virus on my computer and all programs work correctly.
When I uninstalled cygwin I manually deleted the cygwin folder located at
C: \ cygwin and cygwin registry keys,located in the HKEY_LOCAL_MACHINE and
HKEY_CURRENT_USER.
Could you help me?
Thank you very,very much.
FUDForum. Page generated in 0.02731 seconds
