Home » Archived » Buckminster » Git Branches/Tags
Git Branches/Tags [message #554169] |
Fri, 20 August 2010 12:10 |
Carsten Reckord Messages: 139 Registered: July 2009 |
--------------020004060807030307040506
Content-Type: text/plain; charset=us-ascii; format=flowed
Since one of the eclipse projects we build on (Xpand/Xtend) will switch to git soon, I tried to switch our searchPath provider to git, too.
This worked just fine as long as I didn't try using a tag in my cquery.
However, specifying a tag like branchTagPath="/Galileo_SR2" always fails with "No component match found":
org.eclipse.xpand:osgi.bundle: Trying provider
git({0}/xpand,plugins/{1}[/home/creckord/NoBackup/buckminste r/workspace/xpand,plugins/org.eclipse.xpand])
org.eclipse.xpand:osgi.bundle: tags will be searched
master
org.eclipse.xpand:osgi.bundle: No tags were found
org.eclipse.xpand:osgi.bundle: Rejecting provider
git({0}/xpand,plugins/{1}[/home/creckord/NoBackup/buckminste r/workspace/xpand,plugins/org.eclipse.xpand]): No component match was found
ERROR [0001] : No suitable provider for component org.eclipse.xpand:osgi.bundle was found in resourceMap
file:/home/creckord/NoBackup/buckminster/platform.rmap
ERROR [0001] : No suitable provider for component org.eclipse.xpand:osgi.bundle was found in searchPath org.eclipse.xpand
ERROR [0001] : Rejecting provider
Interestingly enough, buckminster says "No tags were found", but if I take a look at the repository that was cloned during the resolution,
it has all the tags.
Do I need to specify the desired tag differently somehow? Or is this not yet supported?
cheers,
Carsten
Content-Type: text/xml;
name="platform.rmap"
filename="platform.rmap"
<rmap xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.eclipse.org/buckminster/RMap-1.0"
xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0" xmlns:mp="http://www.eclipse.org/buckminster/MavenProvider-1.0"
xmlns:pp="http://www.eclipse.org/buckminster/PDEMapProvider-1.0">
<searchPath name="org.eclipse.platform">
<provider readerType="p2" componentTypes="osgi.bundle,eclipse.feature" mutable="false"
source="false">
<uri format="http://download.eclipse.org/releases/helios"/>
</provider>
</searchPath>
<searchPath name="org.eclipse.xpand">
<provider readerType="git" componentTypes="osgi.bundle" resolutionFilter="">
<uri format="{0}/xpand,plugins/{1}">
<bc:propertyRef key="workspace.root" />
<bc:propertyRef key="buckminster.component" />
</uri>
<property key="git.remote.uri" value="git://git.eclipse.org/gitroot/m2t/org.eclipse.xpand.git"/>
<property key="git.remote.name" value="xpand"/>
<property key="git.auto.fetch" value="true"/>
</provider>
source="false">
<uri format="http://download.eclipse.org/modeling/m2t/updates/"/>
</provider>
</searchPath>
<locator searchPathRef="org.eclipse.xpand" pattern="^org\.eclipse\.xpand.*$" />
<locator searchPathRef="org.eclipse.platform"/>
</rmap>
name="xpand.cquery"
filename="xpand.cquery"
<cq:componentQuery xmlns:cq="http://www.eclipse.org/buckminster/CQuery-1.0" resourceMap="platform.rmap">
<cq:rootRequest name="org.eclipse.xpand" componentType="osgi.bundle"/>
<cq:advisorNode namePattern="^org\.eclipse\.xpand$" componentType="osgi.bundle" sourceLevel="REQUIRE" branchTagPath="/Galileo_SR2"/>
<cq:advisorNode namePattern=".*" sourceLevel="REJECT"/>
</cq:componentQuery>
--------------020004060807030307040506--
Re: Git Branches/Tags [message #554185 is a reply to message #554169] |
Fri, 20 August 2010 13:09 |
Henrik Lindberg Messages: 2509 Registered: July 2009 |
Please log an issue.
- henrik
On 8/20/10 2:10 PM, Carsten Reckord wrote:
> to git soon, I tried to switch our searchPath provider to git, too. This
> master
> take a look at the repository that was cloned during the resolution, it
> has all the tags.
> yet supported?
> cheers,
> Carsten
Re: Git Branches/Tags [message #557024 is a reply to message #554185] |
Fri, 03 September 2010 15:40 |
Hi Henrik,
Sorry for the delay... https://bugs.eclipse.org/bugs/show_bug.cgi?id=324441
Carsten
> - henrik
>> Hi,
>> master
>> has all the tags.
>> yet supported?
>> cheers,
>> Carsten
Current Time: Thu Mar 28 21:34:51 GMT 2024
Powered by FUDForum. Page generated in 0.05739 seconds
