Home » Eclipse Projects » Eclipse Platform » Product extensions in Eclipse 3.6
Product extensions in Eclipse 3.6 [message #554062] Fri, 20 August 2010 00:51 Go to next message
Amit Mookerjee is currently offline Amit MookerjeeFriend
Member
We are currently migrating our IDE product based on Eclipse 3.2 to Eclipse 3.6. In our Eclipse 3.2 based implementation we made extensive use of product extensions and referred to them via "*.link" files in the central "eclipse/links" folder.
In eclipse 3.6 we see product extensions being supported with the recommended location for "*.link" files the "eclipse/dropins" folder. However we also see the following problem:
When we refer to multiple product extension locations that contribute multiple versions of the same plugin the platform does not always pickup the latest plugin. Is this a bug in Eclipse 3.6?
Also, we have seen that support for registering product extensions in the UI isn't available anymore. In eclipse 3.2 we had a UI for specifically adding an extension location using the following path
"Help -> Software Updates -> Manage Configuration -> Add an Extension Location"
I believe the update manager has been completely redone and the new "p2" system is the standard mechanism for installing updates. However we have a large customer base which is using product extensions and I would like to know what type of support we can expect in eclipse 3.6 and later.
Any guidance on product extensions in eclipse 3.6 will be much appreciated.
Amit Mookerjee
Re: Product extensions in Eclipse 3.6 [message #554791 is a reply to message #554062] Tue, 24 August 2010 12:05 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
Send to eclipse.technology.equinox.
Amit Mookerjee wrote:
> Location"
> Regards
> Amit Mookerjee
The new system uses the SAT4J resolver to find a solution (plugins and
features that will work together). But the eclipse/dropins folder is a
"best effort" location, so installation can succeed without including
all of its contents.
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Product extensions in Eclipse 3.6 [message #554889 is a reply to message #554791] Tue, 24 August 2010 15:56 Go to previous message
Member
Hi Paul,
Thanks for your message. We figured out the problem on our end. One of the product extensions included plugins that had a dependency that was not satisfied in the system. So the platform loaded plugins from the other extension location that did not have the dependency even though the version numbers were lower. We removed this dependency and the extension location works as expected.
However, the main issue is that eclipse 3.6 does not have first class support for managing product extensions. The APIs for registering extension locations which we used in Eclipse 3.2 are deprecated and we did not find anything equivalent in Eclipse 3.6.We also found some rich discussion on this topic in :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=224145
https://bugs.eclipse.org/bugs/show_bug.cgi?id=305642
We are keen to know if any support will be provided for product extensions in future releases of the platform. We have lot of software products out in the field which is managed via product extensions and supporting these products is essential for us.
Amit
Previous Topic:How to get .swf running in a external browser?
Next Topic:how can i know what eclipse is hanging?
Current Time: Sat Feb 27 01:37:20 GMT 2021
Powered by FUDForum. Page generated in 0.02351 seconds
