Home » Eclipse Projects » EGit / JGit » Freeze when committing
icon5.gif  Freeze when committing [message #553982] Thu, 19 August 2010 14:59 Go to next message
Leif Bladt is currently offline Leif BladtFriend
Hi folks,
if I trigger a commit on my multi-module project, my Eclipse freezes for several minutes before the commit dialog opens. This happens since a couple of weeks (always with the nightly-build) and is very annoying.
Where can I retrieve more information (log files) or switch on, for example, debug messages?
Thanks in advance,
Leif
[Updated on: Thu, 19 August 2010 15:00]
Report message to a moderator
Re: Freeze when committing [message #554053 is a reply to message #553982] Thu, 19 August 2010 21:31 Go to previous messageGo to next message
Robin Rosenberg is currently offline Robin RosenbergFriend
leif.bladt@inxmail.de wrote:
> Hi folks,
> several minutes. This happens since a couple of weeks (with the
There is a log in yourworkspace/.metadata/.log, which is also viewable
int the Errors view. If you can verify that the same problem occurs
with a new workspace, then please report as a bug in bugzilla. If you can
tell when it started going wrong, even better.
-- robin
Re: Freeze when committing [message #558158 is a reply to message #554053] Fri, 10 September 2010 11:29 Go to previous messageGo to next message
There were no errors in the log file. I tried it with a fresh clone from Subversion (just switched the repository my Eclipse workspace references) and it works normal again. Unfortunately I can't tell what action corrupted my repository...
Leif
Re: Freeze when committing [message #559826 is a reply to message #558158] Sun, 19 September 2010 17:02 Go to previous messageGo to next message
Matthias Sohn is currently offline Matthias SohnFriend
With 0.9.3 you can now configure tracing via Ctrl-3 > Configure Git Tracing.
Re: Freeze when committing [message #559880 is a reply to message #559826] Mon, 20 September 2010 08:15 Go to previous message
Matthias Sohn wrote on Sun, 19 September 2010 13:02
Since my original problem has re-appeared, I tried to configure the debug trace. Unfortunately this ended in a NullPointerException, but I already filed a bug for this: (https://bugs.eclipse.org/bugs/show_bug.cgi?id=325718)
Re: Freeze when committing [message #582637 is a reply to message #554053] Fri, 10 September 2010 11:29 Go to previous message
Leif
Previous Topic:[JGit] Where is DirChacheCheckout
Next Topic:An egit push does not change my files
Current Time: Sun Dec 04 07:48:03 GMT 2022
Powered by FUDForum. Page generated in 0.01442 seconds
