Home » Modeling » OCL » [OCLInEcore] Operator ^
Re: [OCLInEcore] Operator ^ [message #553606 is a reply to message #553521] |
Wed, 18 August 2010 07:54 |
Toñi Reina Messages: 209 Registered: July 2009 |
Hi Ed,
thanks for your answer, could you give me any reference about this
CompleteOCL editor?
RE
El 17/08/2010 21:14, Ed Willink escribió:
> Hi Toni
> ^ is a Message operator which is applicable to UML but not to EMOF
> models. Ecore is 'equivalent' to EMOF, so ^ and ^^ are deliberately
> missing from OCLinEcore.
> ^ and ^^ are present in the CompleteOCL editor.
> You're probably going to have to wait until the OCLinEcore editor
> evolves to a UnifiedOCL editore that supports OCL im UML or Ecore.
> Regards
> Ed Willink
> On 17/08/2010 13:17, Toñi Reina Quintero wrote:
>> Hi,
>> I'm trying to write an OCL expression that includes de ^ operator, such
>> as object^method. However, I have errors when I write this expression in
>> the OCLInEcore editor. Has been this operator implemented in OCLInEcore?
>> Thanks in advance,
>> Toñi
Re: [OCLInEcore] Operator ^ [message #553617 is a reply to message #553606] |
Wed, 18 August 2010 08:10 |
Ed Willink Messages: 7655 Registered: July 2009 |
Hi Toni
Essential OCL is defined by the OMG OCL spec as the essential subset to
support meta-model expressions.
Complete OCL is defined (but not as thoroughly) by the OMG OCL spec as
an extended capability to define OCL documents that complement a meta-model.
[OCLinEcore is an MDT/OCL contribution to support EssentialOCL embedded
in Ecore and applies typiucally to *.ecore XMI files or *.oclinecore
text files.]
The MDT/OCL CompleteOCL editor is invoked typically for *.ocl text files.
The RoyalAndLoyal Example project has a large CompleteOCL exzmple.
Ed Willink
On 18/08/2010 08:54, Toñi Reina Quintero wrote:
> Hi Ed,
> CompleteOCL editor?
> RE
>> Hi Toni
>> Regards
>> Ed Willink
>>> Hi,
>>> Thanks in advance,
>>> Toñi
Re: [OCLInEcore] Operator ^ [message #553635 is a reply to message #553617] |
Wed, 18 August 2010 09:21 |
hi Ed,
thanks for your answer. I've been testing the CompleteOCL editor,
and the problem is that it doesn't report type errors. For example,
if I change the first invariant in the RoyalAndLoyal example
inv invariant_ServiceLevel19 :
(Sequence{'a', 'b', 'c', 'c', 'd', 'e'}->prepend('X')) = 1 +
Sequence{'X', 'a', 'b', 'c', 'c', 'd', 'e'}
adding 1+ after the =, the editor should report an error, but it
doesn't. Do you know any OCL editor that can typecheck OCL specifications?
Thanks in advance,
Toñi
El 18/08/2010 10:10, Ed Willink escribió:
> Hi Toni
> meta-model.
> text files.]
> Regards
> Ed Willink
>> Hi Ed,
>> CompleteOCL editor?
>> RE
>>> Hi Toni
>>> Regards
>>> Ed Willink
>>>> Hi,
>>>> expression in
>>>> OCLInEcore?
>>>> Thanks in advance,
>>>> Toñi
Re: [OCLInEcore] Operator ^ [message #553739 is a reply to message #553635] |
Wed, 18 August 2010 16:07 |
Hi Toni
There is a Complete OCL editor as part of the M2M/QVTd project. It was
intended to migrate this to MDT/OCL, but IP issues got in the way and
forced a hurried Xtext-based redevelopment.
Ed Willink
On 18/08/2010 10:21, Toñi Reina Quintero wrote:
> hi Ed,
> thanks for your answer. I've been testing the CompleteOCL editor, and
> Thanks in advance,
> Toñi
>> Hi Toni
>> meta-model.
>> text files.]
>> Regards
>> Ed Willink
>>> Hi Ed,
>>> CompleteOCL editor?
>>> RE
>>>> Hi Toni
>>>> Regards
>>>> Ed Willink
>>>>> Hi,
>>>>> such
>>>>> expression in
>>>>> OCLInEcore?
>>>>> Thanks in advance,
>>>>> Toñi
Current Time: Thu Apr 25 03:42:28 GMT 2024
Powered by FUDForum. Page generated in 0.03930 seconds
