Home » Eclipse Projects » EGit / JGit » helios 64 bit C/C++ - git not working(git not available for 64 bit helios C/C++ for linux version)
helios 64 bit C/C++ - git not working [message #553277] Mon, 16 August 2010 23:45 Go to next message
suresh is currently offline sureshFriend
I am using Eclipse IDE for C/C++ Linux Developers, Version: Helios Release. I have installed git. However, when I look at the team/share menu of eclipse, only CVS option is available.
What to do?
Thanks for support
suresh
Re: helios 64 bit C/C++ - git not working [message #559827 is a reply to message #553277] Sun, 19 September 2010 17:05 Go to previous messageGo to next message
Matthias Sohn is currently offline Matthias SohnFriend
Did you install EGit from the Helios p2 repository which should be pre-configured after installation ? Alternatively you may install it from the EGit repository described in [1].
[1] http://www.eclipse.org/egit/download/
Re: helios 64 bit C/C++ - git not working [message #559850 is a reply to message #559827] Mon, 20 September 2010 05:57 Go to previous messageGo to next message
yes i installed from egit page but it is not working
Re: helios 64 bit C/C++ - git not working [message #644493 is a reply to message #559850] Sun, 12 December 2010 09:32 Go to previous message
Justin Buser is currently offline Justin BuserFriend
I'm having the same problem, tried both repo locations for install and I have no Git menu options available anywhere either in preferences or through right click -> team. I find this odd because I have the exact same installation setup on my work machine and everything is fine.
I'm stumped
Previous Topic:JGit: Glog without command line dependency
Next Topic:EGit trouble with keypass
Current Time: Mon May 25 22:14:48 GMT 2020
Powered by FUDForum. Page generated in 0.01929 seconds
