Home » Modeling » M2T (model-to-text transformation) » JET2 transformation project with multiple transformations
JET2 transformation project with multiple transformations [message #4965] Sat, 17 March 2007 15:44 Go to next message
Vladimir Sosnin is currently offline Vladimir SosninFriend
There is a problem defining additional transformations in JET
Transformation Project. For example, I create the JET2 Transformation
Project prj1. Now I can run JET transformation with id prj1. But if I
add one more transformation into project using org.eclipse.jet.transform
extension point then there is no way to run it using Run configuration.
Despite this, if my new transformation definition is first in list of
defined transformation then it is performed.
I tied to define different IDs for extension points and define different
template loaders but behavior stays the same.
Summary:
How to define several transformations in one transformation project with
ability to run them using launch configuration?
Vladimir
Re: JET2 transformation project with multiple transformations [message #5306 is a reply to message #4965] Wed, 21 March 2007 13:51 Go to previous messageGo to next message
Paul Elder is currently offline Paul ElderFriend
Vladimir:
Currently, each JET transformation must be in a separate project.
Please consider submitting a bugzilla enhancement request if you'd like
more:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=M2T& version=unspecified&component=Jet&rep_platform=PC&am p;op_sys=Windows%20XP&priority=P3&bug_severity=enhan cement&bug_status=NEW&bug_file_loc=http%3A%2F%2F& ;short_desc=&comment=&commentprivacy=0&keywords= &dependson=&blocked=&maketemplate=Remember%20val ues%20as%20bookmarkable%20template&form_name=enter_bug&a mp;assigned_to=m2t.jet-inbox%40eclipse.org&qa_contact=
Paul
"Vladimir Sosnin" <antiso@gmail.com> wrote in message
news:eth2cg$h6n$1@utils.eclipse.org...
> Hello,
> Project prj1. Now I can run JET transformation with id prj1. But if I add
> Summary:
> Regards,
> Vladimir
Re: JET2 transformation project with multiple transformations [message #6442 is a reply to message #5306] Wed, 21 March 2007 19:02 Go to previous message
Done. https://bugs.eclipse.org/bugs/show_bug.cgi?id=178636
I'm not sure in completeness of RFE. It's not clear for me enough how
registered transformations get it's ID. So, I skipped this issue in RFE
description.
Vladimir
Paul Elder wrote:
> Vladimir:
> more:
> Paul
>> Hello,
>> Summary:
>> Regards,
>> Vladimir
Previous Topic:JET2 - How to get the content of a text node
Next Topic:Re: New to JET can't access xsi:type value
Current Time: Fri Mar 24 00:24:52 GMT 2023
Powered by FUDForum. Page generated in 0.02000 seconds
