Re: UML Testing Profile [message #552824] |
Fri, 13 August 2010 16:17 |
Ed Merks Messages: 33140 Registered: July 2009 |
Mohamed,
I don't think there is, but you might ask about it on the UML2
newsgroup/forum. I've added it to the "to" list of the reply.
Mohamed wrote:
> I am a new user of Eclipse, and I'm doing a research on using UML 2.0
> Testing Profile (U2TP) ...
> Is there any implementation for the U2TP on Eclipse?
> Where I can get a good documentation about the subject if available.
> Thanks in advance.
Ed Merks
Re: UML Testing Profile [message #553457 is a reply to message #553122] |
Tue, 17 August 2010 15:20 |
I was building UML Testing Profile according to the UTP specification from omg.org using Eclipse Galileo Modeling version.
I have created some stereotypes such as:
- TestComponent: extends UML::StructuredClassifier
- TestContext: extends UML::StructuredClassifier
- SUT: extends UML::Property
To test the draft profile, I defined it through "UML Editor" menu. Then I created a simple class diagram with three UML classes. I loaded the profile through "load resource", and applied the profile.
I applied TestComponent to one class and TestContext to another class. However, I couldn't apply SUT to the third class (it does not show up).
Any clue?
Thanks in advance.
Mohamed
Re: UML Testing Profile [message #554847 is a reply to message #553493] |
Tue, 24 August 2010 14:25 |
Yes, you are right.
But, this is how SUT is specified in the OMG's UTP.
I thought there are some missing links among the UML metamodel.
I will try to contact the OMG UTP group.
Re: UML Testing Profile [message #628596 is a reply to message #628593] |
Any clue?
Thanks in advance.
Mohamed
Re: UML Testing Profile [message #628614 is a reply to message #628597] |
Yes, you are right.
FUDForum. Page generated in 0.05398 seconds
