Home » Modeling » EMF » Implementing a DSL with Classes, Instances and Function Calls(Creating my own Scope)
Implementing a DSL with Classes, Instances and Function Calls [message #552322] Wed, 11 August 2010 17:36 Go to next message
Christian Ammann is currently offline Christian AmmannFriend
Hi there,
i have a scoping related problem. I Want to implement a DSL which contains classes. A class can contain functions. When i instanciate a class, i want to call the class functions. Here is a simplified example of my DSL:
class Stack{
	operation push();
Stack s1;
call s1.push();
The problem is within the last line: The default scoping only allows me something like:
call Stack.push();
My grammar looks like:
Model:
	(class+=Class)*
	(vars+=Variable)*
	(calls+=Calls)*
Variable:
	type=[Class] name=ID ";"
Class:
	"class" name=ID "{"
		(op+=Operation)*
Operation:
	"operation" name=ID "(" ")" ";"
Calls:
	"call" call=[Operation|FQN] "(" ")" ";"
FQN:
	ID "." ID
I think i have to create somehow my own scope, which uses the instance references instead of the class declaration name.
Thanks for your help in advance,
Christian
Re: Implementing a DSL with Classes, Instances and Function Calls [message #552324 is a reply to message #552322] Wed, 11 August 2010 17:44 Go to previous messageGo to next message
oh sorry, somehow i missed the right forum. can somebody move it to the TMF (Xtext) section?
[Updated on: Wed, 11 August 2010 17:45]
Report message to a moderator
Re: Implementing a DSL with Classes, Instances and Function Calls [message #552375 is a reply to message #552322] Wed, 11 August 2010 23:44 Go to previous messageGo to next message
Christian,
With a newsgroup reader (Thunderbird) you can redirect a post just by
adding the other newsgroup to the reply as I've done here.
Christian Ammann wrote:
> Hi there,
> example of my DSL:
> class Stack{ operation push();
> Stack s1;
> call s1.push();
> me something like:
> call Stack.push();
> Model:
> (class+=Class)*
> (vars+=Variable)*
> (calls+=Calls)*
> Variable:
> Class:
> "class" name=ID "{"
> (op+=Operation)*
> Operation:
> Calls:
> FQN:
> ID "." ID
> Christian
Ed Merks
Re: Implementing a DSL with Classes, Instances and Function Calls [message #552388 is a reply to message #552375] Thu, 12 August 2010 03:09 Go to previous messageGo to next message
Ashwani Kr Sharma is currently offline Ashwani Kr SharmaFriend
Hi Ed,
When i reply using thunderbird, the reply comes with user as anonymous and not my newsgroup account user.
Can this be configured ?
Ashwani Kr Sharma
Re: Implementing a DSL with Classes, Instances and Function Calls [message #552391 is a reply to message #552388] Thu, 12 August 2010 03:17 Go to previous messageGo to next message
Ashwani,
I'm seeing ashw.kumar at gmail.com (with a real @ not just "at") in my
reader, so it looks fine. There's a "From" dropdown that lets you
choose your identity...
Ashwani Kr Sharma wrote:
> Hi Ed,
> and not my newsgroup account user. Can this be configured ?
> Regards,
> Ashwani Kr Sharma
Ed Merks
Re: Implementing a DSL with Classes, Instances and Function Calls [message #552394 is a reply to message #552391] Thu, 12 August 2010 04:43 Go to previous messageGo to next message
Actually i am currently using browser to reply. Hence, the name appears correctly.
I will try the option you mentioned in thunderbird.
Thanks and Regards,
Ashwani Kr Sharma
Re: Implementing a DSL with Classes, Instances and Function Calls [message #552422 is a reply to message #552322] Thu, 12 August 2010 08:07 Go to previous messageGo to next message
oh okay. I didnt know this forum is also a newsgroup. I thought its just a regular forum with moderators, moving wrong posts to the right place Smile
Re: Implementing a DSL with Classes, Instances and Function Calls [message #630697 is a reply to message #552375] Mon, 04 October 2010 15:34 Go to previous message
Lorenzo Bettini is currently offline Lorenzo BettiniFriend
probably this might help: http://fj-eclipse.sourceforge.net/
>> Hi there,
>> example of my DSL:
>> Stack s1;
>> call s1.push();
>> me something like:
>> call Stack.push();
>> Model:
>> (class+=Class)*
>> (vars+=Variable)*
>> (calls+=Calls)*
>> Variable:
>> Class:
>> "class" name=ID "{"
>> (op+=Operation)*
>> Operation:
>> Calls:
>> FQN:
>> ID "." ID
>> Christian
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Previous Topic:Best practice for EMF Notification propagation
Next Topic:Package not available for reloading of model
Current Time: Tue Nov 24 15:55:01 GMT 2020
Powered by FUDForum. Page generated in 0.01884 seconds
