Home » Archived » Service Component Architecture (SCA) Tools » SCABuilder and project dependencies(SCABuilder encounters UnresolvedReference in .composite)
icon5.gif  SCABuilder and project dependencies [message #552247] Wed, 11 August 2010 12:31 Go to next message
Sebastian  is currently offline Sebastian Friend
Hello there,
I'm trying to implement the introducing-tours example from the
TuscanySCAInAction book.
There is a tours.composite file in an Eclipse project called
"Tours" which references a service like this:
<?xml version="1.0" encoding="UTF-8"? <sca:composite
xmlns:sca="http://www.osoa.org/xmlns/sca/1.0" name="tours" targetNamespace="http://tuscanyscatours.com/"
<sca:component name="TripBooking"
<sca:reference name="mytrips" target="TripProvider/Trips"
<sca:interface.java interface="com.tripprovider.Trips" /
</sca:reference
</sca:component
</sca:composite
When I use the SCA Builder or try to open the composite in the
SCA composite model editor, I get an
UnresolvedReferenceException for mytrips and the project
is marked as having an error.
I guess this happens because the service that is referenced
sits in another Eclipse project (Trips). Adding a project
reference from Tours to Trips doesn't help, neither
does adding the Trips jar file to the project libraries.
I was planning a larger development project and was intending
to use one Eclipse project for each composite. This
seemed a natural way to go. If this is technically not feasible,
what do people usually do in Eclipse?
I can't believe the SCA Tools would force one
into putting everything into one single gigantic project.
-- Sebastian
Re: SCABuilder and project dependencies [message #552264 is a reply to message #552247] Wed, 11 August 2010 13:30 Go to previous message
Stephane Drapeau is currently offline Stephane DrapeauFriend
Hi Sebastian,
This is a bug. As you said, a reference from a composite to a composite
located in another project or in a jar file should work.
Can you please fill in a bug?
Thanks.
Stephane Drapeau
Obeo
Sebastian a écrit :
> Hello there,
> </sca:reference
> </sca:component
> </sca:composite
> When I use the SCA Builder or try to open the composite in the SCA
> composite model editor, I get an UnresolvedReferenceException for
> I guess this happens because the service that is referenced sits in
> another Eclipse project (Trips). Adding a project reference from Tours
> to Trips doesn't help, neither does adding the Trips jar file to the
> project libraries.
> I can't believe the SCA Tools would force one into putting everything
> -- Sebastian
Previous Topic:STP SCA-Tools svn server down
Next Topic:SCABuilder and project dependencies
Current Time: Mon Feb 26 12:20:56 GMT 2024
Powered by FUDForum. Page generated in 0.03940 seconds
