Breakpoints not working [message #551482] |
Fri, 06 August 2010 15:10 |
ltwinner Missing name Messages: 2 Registered: July 2010 |
Im working on a drupal project in linux mint. I had been developing it in windows and I was using the Eclipse Helios release for windows. I switched development over to linux mint a few days ago and was using Helios again. However debugging is not working as the debugger doesn't stop at any breakpoints. Im using xdebug but zend debugger doesn't work either.
xdebug is setup correctly with apache and is showing up in phpinfo() so that's not an issue.
Any ideas how to get these breakpoints working? Or does xdebug just not work with Eclipse Helios?
[Updated on: Fri, 06 August 2010 15:42] Report message to a moderator
Re: Breakpoints not working [message #551492 is a reply to message #551482] |
Fri, 06 August 2010 15:52 |
Originally posted by: dkel50.hotremovemail.com
maybe try clearing out all your breakpoints and recreating them.
Alternatively use xdebug and generate an xdebug log to see what PDT is
sending to it in terms of breakpoints (ie filenames and line numbers)
Dave
> either. Any ideas how to fix it?
Re: Breakpoints not working [message #654998 is a reply to message #642234] |
Thu, 17 February 2011 22:42 |
Rylie Messages: 1 Registered: February 2011 |
For me eclipse (Helios) stops at breakpoints ONLY when debugging "as a PHP Script", but not when debugging "as a Web Page".
When debugging as a web page, it looks like the correct debug query string to start a debug session is getting tacked on to the url, like so:
http://localhost/hello.php?XDEBUG_SESSION_START=ECLIPSE_DBGP &KEY=129798139020511
but elipse does not stop at the breakpoints. It just zooms thru the code and displays the output in the browser.
This is my xdebug configuration in php.ini that works for Galileo, but is not working for Helios: (click here to see my entire xdebug config settings)
;extension=xdebug.so <-- is this needed?
zend_extension=" /Applications/MAMP/bin/php5.3/lib/php/extensions/no-debug-no n-zts-20090626/xdebug.so "
xdebug.remote_enable=on
xdebug.remote_autostart=off
xdebug.remote_handler=dbgp
xdebug.remote_mode=req
xdebug.remote_host=127.0.0.1
xdebug.remote_port=9000
xdebug.idekey=
; to enable remote debugging
zend_debugger.allow_hosts=127.0.0.1/32
zend_debugger.expose_remotely=always
Can you post your xdebug configuration that works for Helios? If possible, can you post the xdebug portion of your phpinfo() output? Would like to compare settings of an xdebug configuration that works on Helios with what I have.
Thanks in advance.
[Updated on: Thu, 17 February 2011 23:13] Report message to a moderator
FUDForum. Page generated in 0.03154 seconds
