Home » Eclipse Projects » BIRT » Master Page or(page orientation) Based on the parameter
Master Page or(page orientation) Based on the parameter [message #551454] Fri, 06 August 2010 14:03 Go to next message
JP Redro is currently offline JP RedroFriend
Hi Experts,
I am experiencing an issue with page orientation , If the Parameter is A4 then i have to chose A4 Master page or it has to took default Master page. Please assist me on this.
JP
JP
Re: Master Page or(page orientation) Based on the parameter [message #551473 is a reply to message #551454] Fri, 06 August 2010 14:23 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
JP,
You can always modify the master page settings in the beforeFactory
script like:
importPackage(Packages.org.eclipse.birt.report.model.api.ele ments);
importPackage(Packages.org.eclipse.birt.report.model.api);
//reportContext.getDesignHandle().findMasterPage("myMasterPage ").orientation
= "landscape";
= "portrait";
//reportContext.getDesignHandle().findMasterPage("myMasterPage ").pageType =
"us-legal";
reportContext.getDesignHandle().findMasterPage("myMasterPage ").setProperty("headerHeight",
"0.6in" );
"0.7in" );
Or in the before factory find your table and set its master page like:
rptDesignHandle = reportContext.getDesignHandle();
tbl = rptDesignHandle.findElement("mytable");
tbl.setProperty("masterPage","MasterPageTwo");
And these can be based on parameters as the beforeFactory event has
access to all the parameter values. ie params["MyParameter"].value
Jason
On 8/6/2010 10:03 AM, JP wrote:
> Hi Experts,
> JP
Re: Master Page or(page orientation) Based on the parameter [message #551488 is a reply to message #551454] Fri, 06 August 2010 15:28 Go to previous messageGo to next message
Thanks Jason,
Please drop me example rptdesign.
thanks,
JP
JP
Re: Master Page or(page orientation) Based on the parameter [message #551495 is a reply to message #551488] Fri, 06 August 2010 15:51 Go to previous messageGo to next message
See this example:
http://www.birt-exchange.org/org/devshare/designing-birt-rep orts/1246-set-master-page-properties-using-script/
On 8/6/2010 11:28 AM, JP wrote:
> Thanks Jason,
> thanks,
> JP
Re: Master Page or(page orientation) Based on the parameter [message #551622 is a reply to message #551454] Sun, 08 August 2010 12:32 Go to previous messageGo to next message
Hi Jason,
I am getting 404 exception with this link, Please validate and post me good one.
JP
JP
Re: Master Page or(page orientation) Based on the parameter [message #551774 is a reply to message #551622] Mon, 09 August 2010 14:08 Go to previous messageGo to next message
Jason
On 8/8/2010 8:32 AM, JP wrote:
> Hi Jason,
> good one.
> JP
Re: Master Page or(page orientation) Based on the parameter [message #1802233 is a reply to message #551473] Mon, 04 February 2019 18:39 Go to previous message
Aaron Wideen is currently offline Aaron WideenFriend
Hi All ,
I'm fairly new to the scripting side of BIRT and aside from a few simple scripts I haven't done anything too complex.
I have a situation with a report design where for the first page "master page a" should be used on all other pages "master page b" should be used...
I'm leaning towards a script that could set the masterpage based on page number... Is this possible?
Thanks for the time!
Previous Topic:Sum All Rows based on Value of Field
Next Topic:BIRT 4.8 Update Site
Current Time: Thu Aug 22 16:02:18 GMT 2019
Powered by FUDForum. Page generated in 0.02031 seconds
