Home » Eclipse Projects » Rich Client Platform (RCP) » Eclipse Help Editor
Eclipse Help Editor [message #551155] Thu, 05 August 2010 13:06 Go to next message
Remo Blaser is currently offline Remo BlaserFriend
Hi Folks!
Is there an Eclipse Help Editor in which you can directly Edit the Help in a RCP Project?
If not i would like to ask where i can implementate a Button to Edit the Help Contents?
Greetings
Re: Eclipse Help Editor [message #551334 is a reply to message #551155] Fri, 06 August 2010 04:52 Go to previous messageGo to next message
Prakash G.R. is currently offline Prakash G.R.Friend
On 05/08/10 6:36 PM, Remo Blaser wrote:
> Hi Folks!
> in a RCP Project?
> Help Contents?
> Greetings
The Manifest editor from PDE helps you to create the help content. You
may also want to check out WikiText from Mylyn
- Prakash
Platform UI Team, IBM
www.eclipse-tips.com
Re: Eclipse Help Editor [message #551354 is a reply to message #551334] Fri, 06 August 2010 06:37 Go to previous message
Well the Problem is, they have to change the Help Content while the RCP Application is running.
greetings
Previous Topic:Commercial RCP-Apps and License
Next Topic:Errors in .log after shutting down an RCP application
Current Time: Mon Jan 17 16:18:08 GMT 2022
Powered by FUDForum. Page generated in 0.02262 seconds
