Home » Modeling » Papyrus » Papyrus Extensions(Papyrus Extensions)
icon3.gif  Papyrus Extensions [message #551016] Wed, 04 August 2010 20:36 Go to next message
Keyla  is currently offline Keyla Friend
I have 2 major doubts:
1)Is it possible to add new sub menus to the new Papyrus version on Eclipse Helios (like an extension)? Is there a tutorial somewhere that I could use?
2) Can I configure something on Acceleo to convert a SysML diagram to SystemC?
Please, I really need help, I have to make those modifications as part of a "home work" at college.
Re: Papyrus Extensions [message #555274 is a reply to message #551016] Thu, 26 August 2010 07:34 Go to previous messageGo to next message
Patrick Tessier is currently offline Patrick TessierFriend
For submenu, its possible, you can use extension point popmenu or ui.menus.
Some userguide will be added to explain that.
Convert a diagram is more difficult, do you want remove SysML stereotype and
add new stereotype for System C? or do you want a dedicated diagram for
system C, with new figure new beahvior for element?
"Keyla" <keylamacharet@gmail.com> a
Re: Papyrus Extensions [message #1768364 is a reply to message #551016] Tue, 18 July 2017 01:48 Go to previous messageGo to next message
zhihui Zhang is currently offline zhihui ZhangFriend
Hi keyla,
Have you solved that converting SysML diagram to SystemC codeļ¼Œ in order to finish my master paper, i have to slove this problem. Looking forward to your reply!
Best Regrads!
wisdom
Re: Papyrus Extensions [message #1783218 is a reply to message #1768364] Fri, 09 March 2018 10:07 Go to previous message
Tim Baalmann is currently offline Tim BaalmannFriend
Hi zhihui,
How far did you get with the SysML2SystemC topic and how well did you cope with it? I am currently working on a similar topic and would appreciate to receive some information from you.
Regards.
Previous Topic:Association between metaclass and stereotype
Next Topic:Get and create SysML subprofiles (SysML 1.4 Memtamodel)
Current Time: Wed Feb 19 06:18:52 GMT 2020
Powered by FUDForum. Page generated in 0.02126 seconds
